clutch chatter/rattling noise
Old Nov 7, 2011 | 03:07 AM
sturman8r's Avatar
sturman8r
Default clutch chatter/rattling noise
hey guys, ok so i just drove from Seattle washington to south carolina everything went great. when i got up this morning and drove my car around it started making a weird noise. every time i press the clutch in 1st-3rd i get a chattering/rattling noise for a sec until the rpms go down. any idea what it could be? thanks and any help is greatly appreciated.
here is a video of the noise. thanks
http://youtu.be/jATHn9v9MC0
Old Nov 11, 2011 | 05:12 AM
sturman8r's Avatar
sturman8r
any one have any ideas? i just posted a video
Old Nov 13, 2011 | 05:17 PM
sturman8r's Avatar
sturman8r
Default something is not right!
hey guys no one here has responded to me so im going to post in a different section. if you guys could please watch my video and let me know what you think this might be it would be greatly appreciated. i know there are alot of smart guys in here when it comes to this stuff..... thanks
http://www.youtube.com/watch?v=jATHn9v9MC0
Old Nov 13, 2011 | 05:22 PM
stein's Avatar
stein
Don't run that thing any more! It's broke! Could be anything but it's internal and not good! Get er checked out.
Old Nov 13, 2011 | 06:32 PM
Guilty1s's Avatar
Guilty1s
spun bearing or something is metal bouncing around in your oil pan... thrust bearing??... either way... dont run it anymore till its taken apart.
Old Nov 13, 2011 | 06:42 PM
midz350's Avatar
midz350
It sounds like a spun rod bearing. Happened to me before. GL.
Cass, what do you think?
Old Nov 13, 2011 | 06:54 PM
Cass007's Avatar
Cass007
It sounds louder than my rod knock did, but I never bent the rods, just pounded out the bearings. Maybe a thrust bearing or bent rod that has lost a bearing. Regardless, OP STOP RUNNING IT or you may ventilate the block.
What mods do you have currently?
Old Nov 13, 2011 | 07:01 PM
midz350's Avatar
midz350
I heard mine while going 60mph in the highway.
Old Nov 14, 2011 | 01:38 AM
sturman8r's Avatar
sturman8r
thanks for the responses.... it isnt a rod knock because it would do it all the time. sometimes it will make the noise at 3500 rpm and sometimes not. it sounds like its coming from the bell housing. there is nothing done to the motor. its bone stock with 35k miles. it ran and drove fine all the way from seattle to south carolina and then the next morning i started her up and started getting this noise.....
Old Nov 14, 2011 | 01:50 AM
faiz23's Avatar
faiz23
FEZZZZZZ
No idea man but seems like many think it is coming from the engine. Lets answer a few questions first like what type of motor do you have. Rev-up, DE, HR and how many miles total did you drive on your trip. Did you check your oil before you left, during your trip and after your trip. Does your vehicle consume any oil previously during oil change intervals. Do you feel like it is your clutch or flywheel and how many miles have you driven it since the noise first started.
Edit: Stolen from this post...BTW...OH SH*T SON it just got real...
Actually, it was the 2005 6MT anniversary edition and the track models that came with the RevUp engine.
My 2005 Track model has had no problem with oil consumption, but there are others who haven't been as lucky (and generally have been more vocal).
__________________
You have a rev-up motor aka....NISSAN'S RED HEADED STEP CHILD
https://my350z.com/forum/engine-and-...ong-block.html
Old Nov 14, 2011 | 03:51 AM
sturman8r's Avatar
sturman8r
im not sure what motor it is but the tick doesnt increase with rpms it just makes the same noise. its more of a rattle than a tick since the noise i have driven maybe 10-15 miles. oil consumption in not much if any at all. i have jacked the car up and the noise comes from the bell housing area not in the engine. no check engine lights or anything out of the normal. oil pressure is good and the tranny shifts perfect. i have no idea....
Old Nov 14, 2011 | 03:52 AM
sturman8r's Avatar
sturman8r
also it sounds completely normal until it gets above 2500 rpms. wouldnt a rod not make the noise at even idle?
Old Nov 19, 2011 | 07:20 PM
Itzcashew's Avatar
Itzcashew
must be the clutch arm or bushing. since it only happen when you press the clutch in.
here is my advice: buy a clutch/flywheel combo, new bushings etc. have the trans removed to see whats going on. install clutch/flywheel at the same time.
Old May 20, 2012 | 05:48 AM
KelekonaKustoms's Avatar
KelekonaKustoms
any update on this, my car just started to do the same thing. also two weeks ago i started to have problems with my clutch pedal not returning fully. makes me think clutch/flywheel/bearing issue.
Old Aug 16, 2013 | 03:05 PM
R1runr's Avatar
R1runr
Has anyone solved this issue before I split my drive train any help would be fantastic
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
