overheating issue
Old Nov 21, 2011 | 06:34 PM
samano1616's Avatar
samano1616
Default overheating issue
so i know this has probably been asked but i searched and couldnt find much. now my car just kinda out of no where just started to run hotter than usual so i replaced the thermostat and the coolant and im going to replace the radiator cap now it is still over heating is this because i forgot to bleed the air and when i do will that stop the overheating
Old Nov 21, 2011 | 06:51 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
most likely it's because of the air in the system. You'll need to bleed it.
Old Nov 21, 2011 | 07:08 PM
samano1616's Avatar
samano1616
for sure i did a little more digging and found a guy with the same problem and it was the air that was doin it
Old Nov 21, 2011 | 07:27 PM
Spork's Avatar
Spork
"Forgot" to bleed the air? Why bother do a half-assed job of changing coolant when you overlook the most important part?
At least you found the issue. Best of luck.
Old Nov 21, 2011 | 11:30 PM
terrasmak's Avatar
Bleed is a must on this car, and it can be a PITA.
Old Nov 22, 2011 | 03:26 PM
samano1616's Avatar
samano1616
So i actually drained the coolant again so i could things right. I undid the air relief plug and began to fill it back up with coolant until until it came out of the air relief. I closed up the air relief and left the radiator cap off and started the car. Now instead of the coolant bubbling and then going down through the thermostat it just spilled out all over the place. Keep in mind i just replaced the thermostat. So i called someone and he thinks due to whats happening it's my head gaskets and because the 350z has an aluminum engine the gaskets go bad easier
Old Nov 22, 2011 | 03:27 PM
samano1616's Avatar
samano1616
forgot to mention this guy is a mechanic and is gonna take a look at it next week until then i cant drive though
Old Nov 23, 2011 | 02:38 PM
zakmartin's Avatar
zakmartin
If you want to do it right, you need a decent air compressor and one of these to properly change the coolant in your system. If you can't do that, you really should just take it to a shop that can.
Old Nov 23, 2011 | 03:55 PM
samano1616's Avatar
samano1616
that makes sense but ive done more digging to know if ur head gasket is blown or not and i have 3 a few days ago i drove to some place and back to my house and saw a bit of water in my exhaust tip one sign of a blown head gasket. another was the morning when it began to over heat i was on my way to school and what i thought was just warm air leaving my exhaust like when u see ur breath was thin smoke no one else's car was doing that. the last was overheating before i did anything with the coolant it was overheating and my oil pressure was lower than normal which makes sense with a blown head gasket theres no compression
Old Nov 23, 2011 | 03:56 PM
samano1616's Avatar
samano1616
and i was not moving when the thin smoke was coming out and it only did that at one light i didnt see it again so i thought nothing of it
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
