zero Oil pressure and oil light on
On my way home I noticed out of nowhere the oil light comes on and I'm getting zero oil pressure on my gauge. dipsticked check theres oil. limped it home about 3 miles, didn't hear any knocking. I checked all my fuses and relays all good. I figured it was the oil pressure sensor so I went under and swapped that out. still reading zero oil pressure. Any ideas? I appreciate your help in advance.
Sensor failure, most likely. EDIT: oops, didn't see you had swapped it out. Wiring harness, gauge, or true oil pump failure in that case...
Should I get one of these:
http://www.autozone.com/autozone/acc...ester/_/N-25ml
and just plug it in where the electrical sensor is?
IMO
yes, and if it reads 0, turn the motor off asap. sounds like an oil pump since you swapped sensors and it still read 0.
if new gauge reads good oil pressure, its a wiring problem or you had 2 bad sensors
if new gauge reads no oil pressure, likely an oil pump, which sucks to replace.
