please help ! something is wrong on my oil pis guuage!
Old Jun 13, 2012 | 02:08 PM
imports22's Avatar
imports22
Default please help ! something is wrong on my oil pis guuage!
hey guys i really need your help! i recently got a manual 2005 350z and i changed the oil last night. i used a full synthetic mobil 1 5-30 motor oil and got a mobil 1 oil filter. i have changed the oil on alot of different cars so this isnt new to me.
for some reason today i noticed while i was driving that my oil psi was all over the place! it seemed to be in sync with my RPM's . a.k.a - the hight my RPM went, the higher my oil pressure went. same for when i was idling, it was extremely low oil pressure. i have never had this problem happen when i changed oil so i have no idea what it could be!
i looked under the car to see if maybe i didnt put the bolt on tight enough or the new filter but nothing. then i checked my dipstick but the oil line was right in between the L & H. then i went to Orielly's to see if they had any idea and the guy told me to buy a synthetic oil stabilizer to help thicken it. so i did. i put 1 quart in and still nothing changed.
so now im asking for all of your guys' help!!! i dont know what to do??~?!?!?!?!
Old Jun 13, 2012 | 02:10 PM
imports22's Avatar
imports22
P.S. sorry for the misspelled title. i am at work and threw it together before my next shift
Old Jun 13, 2012 | 02:19 PM
TPete19's Avatar
TPete19
This is normal, you just didn't notice before.
Old Jun 13, 2012 | 02:21 PM
imports22's Avatar
imports22
really? im pretty sure it wasnt before i changed the oil.. it would stay at 60 PSI. it never went up and down with my RPM's.
Old Jun 13, 2012 | 02:46 PM
hookah's Avatar
hookah
Nope its normal. The more I step on it the higher it goes cuz there is more pressure. With a cold start mine starts up at around the middle area. But if I start the engine when its warmed up itll start at low. Other than that when driving it it'll go all over the place depending on how you drive it.
The only thing you need to worry about is when you do a cold start the gauge shouldn't be too low or too high. If it looks unusual at a cold start that is when you worry about it.
I just got my car too. I am sure someone will explain it way clearer than I have haha.
So just make sure when you do a cold start it always starts around the same area... Right guys o_0
Old Jun 13, 2012 | 04:28 PM
bmccann101's Avatar
bmccann101
it varies. Correct. ANd is different at start up, correct.
Good job on paying over attention instead of the usual under attention to these thngs tho.
Now come over here and buy my new drilled brake rotors from me.. lol.
im local... and your thread has now been jacked.
Old Jun 13, 2012 | 04:40 PM
laurentj23's Avatar
laurentj23
Rules of physics when fluids is cold, the viscocity of the oil cause it to have higher psi till it goes to normaloperating temp. Thats the reason people idle their car when it is cold.
Just make sure the pressure is not low which can means oil switch mafunction, oil leak ect ect!
Old Jun 14, 2012 | 12:37 PM
imports22's Avatar
imports22
k thanks guys i really appreciate it!
Obadabot
Jun 18, 2023 11:31 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
