Can TPMS warning light burnout?
Old Jun 19, 2012 | 11:51 PM
goracerx's Avatar
goracerx
Default Can TPMS warning light burnout?
It's been a few weeks and I keep forgetting to remove air to test if they are working. I always remember while i'm driving or about to go to sleep. So, it may be a coincidance, the dealer may have reset them or put them in learning mode for free with my oil change. I have 370Z Nismo rims with OEM 370Z TPMS sensors.
I haven't ordered new tires yet (may get Hancook v12's tonight), so was putting it off swapping the TPMS from original wheels.
If I can actually remember to take some air out and test them, i'll post a reply. If I burned out the light then maybe I don't have to swap them out.
Old Jun 20, 2012 | 12:45 AM
jomamahama's Avatar
jomamahama
yeah it's a useless POS on like every car because they are faulty so often people ignore them, like car alarms.
Old Jun 20, 2012 | 08:27 AM
terrasmak's Avatar
I wish my tps and airbag light would burn out
Old Jun 20, 2012 | 12:22 PM
Michla22's Avatar
Michla22
The LEDs can technically burn out but the chances are slim - they have a life span of about 50,000 hours unless they get too much current of course. So they probably reset it.
Old Jun 20, 2012 | 12:45 PM
Voboy's Avatar
Voboy
This Lol. but i think they are LED's? wonder how difficult it'd be to take it all apart and remove them.
Old Jun 20, 2012 | 12:57 PM
bmccann101's Avatar
bmccann101
it sounds ghetto because it is.. but its soooo nice anyways.... :
Took a piece of black vinyl i had laying around.. cut a nice smooth circle out of it.. quite small i might add.
placed in my field of vision over the airbag light.. took me 120 seconds and now i really dont even see the thing lol.
One day Ill order the correct resistors, but for now.. its a fancy strip of black tape over the gauge face working just fine for me.
Old Jun 20, 2012 | 01:27 PM
goracerx's Avatar
goracerx
Lets see if I can remember in an hour when I get in my car
Well, if the dealer reset them that means 2009 370Z Nismo TPMS works on my 2008 GT Roadster.
Old Jun 20, 2012 | 01:43 PM
Michla22's Avatar
Michla22
If you have soldering skills not very difficult. If you don't - don't bother - a replacement cluster is~$200+ if you mess it up.
However taking it apart and covering the led is a viable option.
Old Jun 20, 2012 | 01:44 PM
Voboy's Avatar
Voboy
^- do you have any instructions on removing it from the dash? Seems simple enough.
Old Jun 20, 2012 | 02:56 PM
lbarge85's Avatar
lbarge85
If you get in the car and turn the ignition on w/o starting the car the light should come on during the bulb check...
Old Jun 21, 2012 | 11:50 AM
Michla22's Avatar
Michla22
More info than you need is located here:
https://my350z.com/forum/exterior-an...version-2.html
Old Jun 21, 2012 | 03:51 PM
goracerx's Avatar
goracerx
Cool thanks, I can remember that. ...I think.
Old Jun 21, 2012 | 04:56 PM
DavesZ#3's Avatar
DavesZ#3
Like any other light on the dash, when you first turn the ignition to the ON position (no need to start), all the lights should illuminate for a few seconds. That's the "test" to see if they are working or not.
You have 370Z TPMS sensors on a 350Z? That don't work.
Old Jun 21, 2012 | 10:06 PM
goracerx's Avatar
goracerx
Yes, both the ABS and TPS light for about two seconds.
Yes, I have 2010 370Z TPS on LM5 wheels. So either...
  • it relearned over time
  • was a coincidence the light went out after the oil change
  • delear reset or put in learn mode
  • all 4 TPS are burned out
Old Jun 21, 2012 | 10:15 PM
RMichael's Avatar
RMichael
do0d, you know it's gonna come on after X miles. If it bothers you that much, shut the car off then quickly back on while you're driving and it'll reset.
Old Jun 21, 2012 | 10:29 PM
mattleegee's Avatar
mattleegee
same frequency, im curious to figure out you find out since im getting some 370z wheels w/tpms on my 350z also
Old Jun 22, 2012 | 04:42 PM
goracerx's Avatar
goracerx
Verified
Lowered rears about 5 seconds worth but no light after one mile. Pulled over and took out another 10 seconds worth and it came on in about 100'. It was approximately 25/24lbs when I got home (not cold pressure).
When I was about to leave today I remembered to fill them up becuase I took way too much out the night before I felt the difference driving. The light turned off after I backed out of the garage.
Ovcourse, I can't gaurantee it will work on other years or models. I have a 08' GT-R which is pretty much the same as '09 as the 370's came out in 09'. It could also be possible that certain receivers match up with certain TPMS units and I just got lucky.
Old Jul 19, 2012 | 11:05 AM
losmt2's Avatar
losmt2
an alternative to taking out the LEDs that bother you like tpms, airbag, check engine if you open the cluster just cover them.
I replace the lighting so I have a blue cluster not and some LEDs run in pairs of groups or taking one out or making it fail might affect other ones as well.here a pic of my FB showing my cluster and you can see them in my youtube as well
http://www.facebook.com/#!/photo.php...type=3&theater
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
