hydro e-brake +unplugged ABS = no speedometer. any help?
Old Jul 22, 2012 | 11:28 AM
theianmcdougall's Avatar
theianmcdougall
Default hydro e-brake +unplugged ABS = no speedometer. any help?
Its a 04 z.
Yesterday i installed my PBM hydro ebrake. and in doing do you have to disable ABS for this brake to work in the Z. To disable ABS i just unplugged the harness going into the ABS block. Now my speedo doesnt work...
Not sure why this would effect my speedo, but it does
Old Jul 22, 2012 | 11:42 AM
PracticeDrifter's Avatar
PracticeDrifter
nice to hear about drift modifications!
I have not done a hydro ebrake install, there are several threads about it. The one thing that connects the speedo and ABS systems is that they both run off of the wheel-speed sensors. there are other ways to disable ABS than unhooking that whole harness.
In my car I have just one wheelspeed sensor that went out, and that knocked out ABS and VDC but not the speedo. Maybe put some of them back in, or check the threads about ABS disable.
https://my350z.com/forum/brakes-and-...too-early.html
https://my350z.com/forum/brakes-and-...sable-abs.html
https://my350z.com/forum/brakes-and-...rn-of-vdc.html
Old Jul 22, 2012 | 12:19 PM
Quamen's Avatar
Quamen
Like above your speedo is run thru the ABS system.
Old Jul 22, 2012 | 05:06 PM
ErasmoHar's Avatar
ErasmoHar
Old Jul 22, 2012 | 07:39 PM
theianmcdougall
ima try plugging the ABS harness back in and removing the ABS fuse instead, hopefully mt speedo will come back
the hydro brake works awesome tho, locks the rear with ease
Old Jul 23, 2012 | 10:24 AM
str8dum1's Avatar
str8dum1
speedo does not run thru abs. at least not on my G35 as I have had my grey abs connector disconnect for months with no effect to my speedo.
theres a transmission sensor
Old Jul 23, 2012 | 10:49 AM
Quamen's Avatar
Quamen
The Z does not got thru the transmission. My speedo still worked with the LS1/Th400 in it. I run an aftermarket speedo now since I removed the ABS.
Old Jul 23, 2012 | 10:05 PM
theianmcdougall
After plugging in the ABS harness my speedo works again. To turn ABS off, i disabled part of the pink fuse next to the battery.
Old Jul 23, 2012 | 11:49 PM
pavelecwikl's Avatar
pavelecwikl
Old Nov 27, 2012 | 03:27 PM
SPirtle's Avatar
SPirtle
So how do you go about pulling that fuse because one I pulled the pink block my car wouldn't run
Old Nov 27, 2012 | 05:16 PM
terrasmak's Avatar
Just disconnect a front wheel speed sensor , speedo runs off the rear
Old Jan 7, 2013 | 03:53 PM
zach711f's Avatar
zach711f
The reason it wont start is because u pulled the entire fuse. That pink fuse controlls abs and ignition. Just snip the two 30 amp fuses under that clear cover and ur good to go. Just make sure you dont cut the ignotiin one. Just look at ur fuse cover
aarrgghh
May 1, 2022 11:04 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
rummya87
Nov 9, 2003 03:11 PM
Cyase
Drift
May 31, 2003 02:45 PM
