Whistling noise, sounds like winding up in a way
Old Aug 7, 2012 | 10:10 AM
Bruno350z's Avatar
Bruno350z
Default Whistling noise, sounds like winding up in a way
A few weeks after I bought the car I noticed the 3rd gear synchros was going out, it grinds going into and leaving 3rd gear when the car is warming up. But once it's running for a while that problem disappears so it doesn't bug me much.
But as of last week it started making this whistling noise, like something is winding up as I'm speeding up. It stops 4-6 gear but 1-3 is always winding. I heard it could be the pilot bushing and the throwout bearing?
Should I just continue driving it till the entire tranny gives out? Replace the tranny now to avoid anything major or is there a quick fix I can do?
Any help would be appreciated =)
Old Aug 7, 2012 | 12:06 PM
BipJip's Avatar
BipJip
check your fluid level. normaly when it is low on fluid it whines. if the bearings were starved from fluid they will whine and thats a major problem (tranny rebuild time). so add fluid if needed and if it persists you'll have to rebuild or replace the tranny.
Old Aug 7, 2012 | 12:11 PM
Bruno350z's Avatar
Bruno350z
I'll check the fluid in a bit, I'll let you know how it is.
What would be better either way, a tranny rebuild or just buying a CD009?
Old Aug 7, 2012 | 12:24 PM
F34RL355's Avatar
F34RL355
mine makes these noises too, more noticeably after getting a new transmission, its notchy as hell into 3rd sometimes... cd009 i must have that as mines an HR could they have put a old rev in mine?!?!?!
mine whines 1st 2nd not as much in 3rd under 3krpm. and when slowing down in gear the z whines like crazy its a whining machine. is this not normal?
Old Aug 7, 2012 | 12:43 PM
Bruno350z's Avatar
Bruno350z
Sounds similar to mine, I'm hoping its the tranny fluid. I'll change the fluid over the weekend and let you know how it works.
What's the best type of fluid to use?
Old Aug 7, 2012 | 01:16 PM
F34RL355's Avatar
F34RL355
i have a little over a year left on warranty, im gonna have to push for a new one again i guess. mainly do to the notchy 3rd gear, its feels like it hits metal on metal with no grinds hmmmmmmmm
Old Aug 7, 2012 | 04:48 PM
aaron.cobb3's Avatar
aaron.cobb3
mine has done this since I've had it (only about a year). Replaced fluid and replaced my clutch about 500 miles ago with a new TO bearing and all and still makes the noise.
I haven't noticed any trouble getting into gear or any grinding though
Old Aug 7, 2012 | 06:12 PM
realist alive's Avatar
realist alive
i have to say it......do you have a pop charger.......just asking
Old Aug 8, 2012 | 02:28 PM
aaron.cobb3
I don't know if you're asking myself or OP but I do not. I have an intake but this is definitely a different sound. My sound is definitely a mechanical sound, like it's winding. And mines a CD009 as well.
When I changed my clutch the fluid looked good and we changed the fluid out and put the recommended amount in it.
Old Aug 8, 2012 | 04:22 PM
805350z's Avatar
805350z
turn the car on while on a lift or jackstands, is it louder near the oil pan? if so, change oil.
Old Aug 8, 2012 | 04:37 PM
Bruno350z's Avatar
Bruno350z
no i do not lol
hmm, i'll definitely give this a shot. I gotta wait till saturday so I'll post again then
Old Aug 8, 2012 | 04:43 PM
ModBargains.com's Avatar
ModBargains.com
Vendor - Former Vendor
The only time I experienced something like this was with my EVO 9 when the transfer case went bad. The whining/whistling noise grew louder through gears. So maybe somethings wrong with the drivetrain?
-Frank
Old Aug 8, 2012 | 04:52 PM
Bruno350z's Avatar
Bruno350z
-Frank
Only difference I see is the whistling starts off loud on my car and gets quieter and almost completely disappears higher speeds
Old Aug 17, 2012 | 02:21 PM
Bruno350z's Avatar
Bruno350z
Turns out it is something to do with my radio. My friend noticed the whistling, turned my radio off to hear it clearer and the noise stopped. Great, now I have to figure which wires are crossing.
Old Aug 17, 2012 | 05:55 PM
DeanFX's Avatar
DeanFX
That sounds like an amp ground issue.
Old Aug 20, 2012 | 11:45 AM
Bruno350z's Avatar
Bruno350z
I'll check out my ground cables, might be it tho cuz I half assed the grounds lol
Obadabot
Jun 18, 2023 11:31 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
wanderingstuden
Jan 28, 2016 07:03 PM
samansharif
Sep 25, 2015 12:31 PM
