CEL TCS OFF and SLip light on!!!!!!!
Old Aug 19, 2012 | 05:51 PM
daytona7135's Avatar
daytona7135
Default CEL TCS OFF and SLip light on!!!!!!!
So i replaced my clutch the other day, and when i finally got it all done, i went to start my car, and it just kept turning over. After about five times it finally came on. Now my CEL TCS off and SLIP lights are on. Also when i am driving, i can feel the engine sputtering a little bit. Did something go wrong with the clutch install, is it another sensor that may have gone out? PLEASE HELPP!!!!!!!
Old Aug 19, 2012 | 09:51 PM
patrickoneal's Avatar
patrickoneal
Did you remove and reinstall the crank position sensor when you removed and reinstalled the transmission? It's on the passenger side of the transmission housing, near the top, right over the flywheel. If you didn't remove it, you may have bashed it into the flywheel during your clutch install. Or perhaps you forgot to plug it back in?
If you search a bit, there are a few threads mentioning an incorrectly installed flywheel causing similar issues. Apparently some of them can go on two ways.
Codes would be helpful here as well.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
