Compression Test Result
Old Aug 22, 2012 | 10:17 PM
BlueDragonZ's Avatar
BlueDragonZ
Unhappy Compression Test Result
I'm thinking with these results the head gasket is definitely blown?
Could the pistons/rings also be damaged?
Driver Side (left to right)
Dry/Wet
#1 125/175
#2 165/195
#3 130/170
Passenger Side (left to right)
Dry/Wet
#4 90/120
#5 90/120
#6 210/225 The coil pack on this cylinder was covered with oil with melted chocolate like consistency. All removed spark plugs was covered with oil.
Old Aug 23, 2012 | 03:09 AM
bmyles's Avatar
bmyles
Yikes man, those are terrible, terrible numbers. You know you have a definite problem, so usually the next step is a leak down test, which will tell you if it's valves, rings, etc.
Old Aug 23, 2012 | 04:30 AM
rich2342's Avatar
rich2342
hmmm, non-rev?
Old Aug 23, 2012 | 07:17 AM
BlueDragonZ
Yeah thats my next step...its a non rev engine 03 with 78k+ miles.
So if i get bad result from LD Test, what my best option...engine replacement?
Old Aug 23, 2012 | 08:30 AM
str8dum1's Avatar
str8dum1
best option, sell the car as is and move on
Old Aug 23, 2012 | 09:13 AM
Duckeee's Avatar
Duckeee
you cant be srss.
just rebuild the engine. go alphaforgedpistonsrodscams etc.
selling it as is is the last thing you should do.
Old Aug 23, 2012 | 03:01 PM
bmyles's Avatar
bmyles
You have 3 options:
1) Buy a low mileage motor. Try car-part.com. I think last I checked, they had some on there for $1500 or around there.
2) Rebuild motor with keeping factory rods and probably even your pistons. You probably just need the block bored (or just honed if you're lucky) and new rings, along with all new gaskets and all that jazz.
3) Build your motor for an insane turbo setup. This will cost a lot, of course, but some people use a dead motor as an excuse
Old Aug 23, 2012 | 05:16 PM
BlueDragonZ
Thanks...im staying NA but im definitely using this as an excuse to build the engine a bit. Im doing some research to see whats the best route to go.
Originally Posted by bmyles
You have 3 options:
Old Aug 24, 2012 | 03:20 AM
bmyles's Avatar
bmyles
But making N/A power is so expensive, haha. If it's what you want to do, more power to ya. I remember 6 years ago, I wanted a crazy cammed 4.15L stroker, but the power/$ for that is just nonsense.
Old Aug 24, 2012 | 10:22 AM
str8dum1's Avatar
str8dum1
sure I am. Its an 03 with 80k miles. The cost of a motor is like 1/4 the cost of the entire car, esp if you cant do your own work.
Originally Posted by Duckeee
you cant be srss.
Old Aug 27, 2012 | 10:14 AM
BlueDragonZ
Still haven't completed a leak down test but I'm assuming the worse at this point. I'mdoing my research but I'm a complete noob when it comes to this....
I'm getting quotes from various companies from 2k-4.5k for a new engine...???...I'm also looking at sites such as Z1/Forged etc for their built engine but unsure which route to go. What should I look out for when looking into a new engine.... mileage/condition/warranty???
Anyone familiar with Rydellpowertrain.com? Got a quote for a long block for 4.5k with 3 year 100k mile warranty
vs. stage 1 long block from Importspartpro.com at 4.5k.
issyz
Jul 2, 2017 03:04 PM
