Car will not start, battery issues?
Old Feb 18, 2013 | 11:02 AM
DCJodon's Avatar
DCJodon
Default Car will not start, battery issues?
I have a relatively new battery (~5 months), and recently my car would not start, I would turn the key, cluster lights up, fuel pump primes, and the second I turn it to ignite, the battery dies (dome lights go off, cluster goes out). I looked at the terminal connections, and noticed the ground (negative) wire was very loose on the post, and it was as tight as it would go. Yet, it would still easily fall off. I wasn't able to start my car without a jump. This past weekend I got around to replacing the ground (negative) wire and connector, and now I have a solid, tight connection to the battery. It started up in a snap, and continued to work great for 2 days. Today, the original issue returned. The car refuses to ignite and the battery (supposedly) dies. I haven't got a chance to test the volts directly off the battery, but with the engine running, the interior volt meter reads the normal 13.5-14 Volts (alternator working and charging). I drove it 80 miles today, shut it off, and it still died on ignition when I tried to turn her back on. I don't get it. What could be wrong? Starter?
03 Base Model
Old Feb 18, 2013 | 11:28 AM
Tracktimeplz's Avatar
Tracktimeplz
If its cutting off, while driving, its not the starter, as its only used to crank the car, not while its running.
It sounds to me, like you have a ground that is loose. Check the chassis grounds for the alternator and battery.
Old Feb 18, 2013 | 01:12 PM
DCJodon's Avatar
DCJodon
Car never shut off while running, even before replacing the battery ground. The issue is only starting. I'll check the alternator ground. My new battery ground is tighter than fort knox.
Old Feb 18, 2013 | 02:06 PM
VO...'s Avatar
VO...
Administrator
Sounds like the battery is gone from all the depletions caused by a loose ground. Acid based batteries cannot be depleted too many times or they will no longer hold a charge...
Old Feb 18, 2013 | 02:13 PM
DCJodon's Avatar
DCJodon
You might be right. I'll get the battery tested and most likely replaced.
Old Feb 18, 2013 | 02:25 PM
VO...'s Avatar
VO...
Administrator
I use the Optima Yellow Top personally. It's an acid free battery that can be depleted numerous times, yet still recharge to 100%. Just an option. They are pricey however...
Old Feb 18, 2013 | 02:38 PM
ZS14RR's Avatar
ZS14RR
Who's this Vo brovato?^^
Old Feb 18, 2013 | 02:40 PM
VO...'s Avatar
VO...
Administrator
I dunno, some ghost that shows up every now and then...
Old Feb 18, 2013 | 03:38 PM
Tracktimeplz
Im sorry! I misread your OP, where you said "Shut it off" I thought you said, "it shut off"
Did you get a chance to test the battery with the engine off yet?
aarrgghh
May 1, 2022 11:04 AM
m_0g
Jun 3, 2021 10:05 AM
OdesiTT
Sep 30, 2015 10:47 AM
Katie93
Sep 15, 2015 05:57 PM
Darkspy
Sep 7, 2015 09:09 PM
