Noise at 1250RPM
Old Apr 17, 2013 | 05:22 PM
!Z!'s Avatar
!Z!
Default Noise at 1250RPM
Hey guys I have a slight problem. I notice a noise a few months ago with my 07 350z HR. At 1250RPMs it will make a small chatter or some type of noise it seems to be coming from the passanger side camshaft or long the front of the engine. Once the engine is over or under 1250RPMs it will stop and sometimes it doesn't make the noise at all.
Old Apr 17, 2013 | 07:03 PM
zJames's Avatar
zJames
mileage? it could be a loose heat shield. do you have high flo cats by any chance?
Old Apr 17, 2013 | 08:42 PM
DarkCreep's Avatar
DarkCreep
Throw out bearing? Mine is loud as hell.
Old Apr 18, 2013 | 06:18 AM
redline06's Avatar
redline06
I think I may know what youre talking about, mine has been doing it for the longest time. Best way I could describe it is it sounds like a tiny newer diesel VW Jetta lol , I always get it when cruising in a parking lot in first gear
Old Apr 18, 2013 | 08:14 AM
!Z!'s Avatar
!Z!
No it has stock cats on it. Its an auto so its not the throw out bearing.
Old Apr 18, 2013 | 08:15 AM
!Z!'s Avatar
!Z!
Yea I hear it at a low speed at 1250RPM SOMETIMES. But did yours damage anything. on yours.
Old Apr 18, 2013 | 09:56 AM
redline06's Avatar
redline06
So far everything is still good, I have 116k miles without any problems
Old Apr 22, 2013 | 06:09 AM
!Z!'s Avatar
!Z!
I wish I knew what it is so I can get it fixed cause it makes my car sounds like junk.
Old Apr 25, 2013 | 04:54 PM
BIGPOPPAPUMP's Avatar
BIGPOPPAPUMP
Sounds like the fuel dampener line. It is on the passenger side & makes this noise. The line get's hot or just cracks over time. I have a ping at 3200rpms & this TSB kept coming up. They even show you a diagram. I don't think it's my issue but yours sounds almost verbatim of this. Not sure if you are hearing the chatter of the diaphragm, the vacuum loss or injectors as a result. Worth a look or read.
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
