Stall out after coming down from RPMs
Old 04-19-2013, 10:37 AM
Kyle1488
Kyle1488's Avatar
Default Stall out after coming down from RPMs
Hey yall,
I've had my 03 Z for about a year now with about 112k miles. Starting about a week ago I've had this issue... I'll accelerate under load, in any gear, up to about 5k RPMs, then while slowing down, I push in the clutch and the as the RPMs should drop to idle, RPMs surpass the idle limit and the car stalls out... Or when I'll downshift to slow down, rolling to a stop the car will stall out after pushing in the clutch. Pretty weird.
My thoughts are its related to a fuel issue... any suggestions?
Old 04-19-2013, 11:21 AM
Syner
Syner's Avatar
Not sure, but it really doesn't sound like a fuel issue to me.
Old 04-19-2013, 12:27 PM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
Any recent mods/changes?
Old 04-23-2013, 05:01 PM
Kyle1488
Kyle1488's Avatar
No recent changes/mods done... I tried doing a hard reset for the system which didn't work either. It stalls after startup sometimes as well.
Old 04-23-2013, 05:29 PM
350z006
350z006's Avatar
Maybe a bad/dirty MAF...
Old 04-23-2013, 08:03 PM
NoQuestionZ
NoQuestionZ's Avatar
My HR stalled after start up today. I'm suspecting MAF as well. Crappy weekend with my car spilling into the week
Old 04-23-2013, 08:08 PM
oldschool350z
oldschool350z's Avatar
Clean the MAF, reset the ECU and report back
Old 04-24-2013, 07:30 AM
Kyle1488
Kyle1488's Avatar
Ok I'll give it a shot. Thanks!
Old 06-02-2013, 05:06 PM
Kyle1488
Kyle1488's Avatar
Cleaned the MAF sensors and TB. Replaced spark plugs just to cross that off the list, as i got to the last cylinder i noticed a little oil in the chamber. Ive read about this and it appears to just be the valve cover seal, no biggie. But every time i accelerate, around 4500 rpms it feels like the car just goes into limp mode, and does not feel like full power. Car starts up rough sometimes as well.. could this be fuel related?
Old 11-04-2013, 04:19 PM
cchmelir
cchmelir's Avatar
Hey just wondering how you fixed it? the exact same thing you are describing is happening to mine. this has happened to me one day about 4 months ago and then went away. i just changed out my spark plugs and this started again. look around don't see anything wrong that i can see. no vacuum leaks or anything. i have a leak in my exhaust but i dont think that would cause this. any help would be awesome! thanks guys!
Old 11-04-2013, 05:13 PM
terrasmak's Avatar
Received 2,297 Likes on 1,654 Posts
Throttle body reset, seems to need it everything the ECU is reset
Old 02-05-2014, 07:14 PM
ctt_g35
ctt_g35's Avatar
i am having the same issue with my 07 g35. been through 3 mechanics and 3000dollars and its only gotten worse. nissan reset timing chain. tried different throttle bodies. tested a bunch of stuff but didn't find anything. they quoted me a new stock engine for 17k.
idle is erratic. will hold steady then dip then rise then settle then repeats. engine stalls when disengaging the clutch intermittently, more often than not, when slowing down or accelerating quick then quickly disengaging with also cause the stall nearly every time. loss of overall power.
please please please help me
this thread talk about the issue being faulty CPS. are they talking about crankshaft sensors or camshaft sensors? https://my350z.com/forum/maintenance...in-clutch.html
at the beginning my CEL wasn't on but after the 3rd mechanic(nissan) it remained on. im going to try to take it to advanced auto tomorrow to get a code reading.
take note that i never had this issue until my engine began overheating in slow traffic and i had the 1st mechanic(home mechanic) replace the radiator(stillen that i ordered) and a fan(a cheap 150$ one he ordered) that nissan said was backfeeding causing problems. replaced with oem 650$ fans
any replies are greatly appreciated as ive been battling this issue for the past 6 months
Old 03-14-2020, 11:05 AM
zleviz
zleviz's Avatar
I have the same exact issue you have with the overheating and all, did you find out what's causing it?
Old 03-14-2020, 02:45 PM
travlee
Master
travlee's Avatar
Received 9,067 Likes on 6,530 Posts
6 year dead thread.
Do people not pay attention to the last post date?
Obadabot
06-18-2023 11:31 PM
08-06-2021 06:19 AM
sherm
04-11-2020 05:21 PM
Justin100
11-29-2015 03:58 PM
samansharif
09-25-2015 12:31 PM
Quick Reply: Stall out after coming down from RPMs
