Need help with hatch
Old Jul 8, 2013 | 06:30 PM
2003Silver350Z's Avatar
2003Silver350Z
Default Need help with hatch
My 2003 Z's hatch randomly unlocks itself pretty regularly when the car is unlocked. I have bought a new remote and even left the remote at home with no difference in the problem. When I lock the car it's fine, but you can be driving and it will come unlocked and pop up. Also, the bottom of the hatch now leaks near the lock and not sure if its related. Help!!
Old Jul 8, 2013 | 08:15 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Nissan builds solid bodies, so somethig is out of alignment for the hatch to pop open like that. I'd start by checking the hatch struts and making sure they are both properly aligned. Something is putting tension on the hatch itself and causing it to pull away from the latch.
Old Jul 14, 2013 | 02:38 PM
2003Silver350Z
Default Rear hatch randomly unlocks
My 2003 350z will often times unlock the hatch on it's own while it is unlocked (even while driving!). It doesn't fly open obviously, but it does come unlatched unless I lock the doors once inside. Bought a new remote and even left the remote at home with no improvement. Also, the hatch tends to leak near the bottom during a hard rain while parked (if not leaking while parked then it will once you take off from the momentum moving the water into the interior). Not sure if the two are related or not, please help !
Old Jul 14, 2013 | 02:46 PM
2003Silver350Z
Well, I have had the car about 2 years without any problems related to the hatch (other than the struts not really working). When it unlatches, you can hear the motor for the latch working to try and unlock the hatch even though it is already open. It's odd because once the latch in unlocked/popped up, the motor will keep activating half a dozen times or until it decides to quit.
Old Jul 14, 2013 | 03:01 PM
KingBaby's Avatar
KingBaby
Hardest Setting
You have a short in your BCM....sucky deal. You can disconnect the connection so that it doesn't pop.
Old Jul 14, 2013 | 03:04 PM
2003Silver350Z
any other way to fix it??
Old Jul 14, 2013 | 03:08 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Yes...of course you can replace the BCM. Total cost here in Hawaii including labor was $600, I read its cheaper of course stateside...
Old Jul 14, 2013 | 03:17 PM
2003Silver350Z
man that sucks, I guess ill just have to continue being cheap ;P
Old Jul 14, 2013 | 04:08 PM
Waiz's Avatar
Waiz
Threads merged since your other one was in the incorrect section...
I would get your lock looked at if it's leaking water, that might be your cause.
Not sure if it would be the BCM if this is your only issue
Old Jul 14, 2013 | 04:26 PM
RMichael's Avatar
RMichael
way cheaper stateside.
Old Jul 14, 2013 | 04:57 PM
2003Silver350Z
I doubt it's the BCM just because I'm not not having any other kind of electrical issues *knock on wood*
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
CottonWoodz
Jan 19, 2003 04:21 AM
