car won't go into gear. HELP!!!!
Old Nov 19, 2013 | 04:06 PM
tony_theturtle's Avatar
tony_theturtle
Default car won't go into gear. HELP!!!!
so like the title says my Z won't go into gear. Its an 03 i just had the JTW combo installed about a month ago with the ssc line. i turned the car on this morning and the shifter was locked out. when the car is off it shifts smoothly. I replace the master and the slave cylinder and bled it for a couple of hours. I bled it the old fashion way and i tried to gravity bleed it. Went thru a couple quarts of brake fluid. the clutch pedal is nice a firm and returns perfectly when the car is off. When i turn the car on, the pump is smooth and the car goes into gear. once i let of the clutch is depress it again it gets soft and the gears lock out again.
any suggestion would be greatly appreciated
Old Nov 20, 2013 | 04:22 AM
tony_theturtle
anyone ? i could really use some advice
Old Nov 20, 2013 | 04:59 AM
dcains's Avatar
dcains
It took me 5 seconds to search for this thread:
https://my350z.com/forum/maintenance...not-bleed.html
Old Nov 20, 2013 | 05:43 AM
tony_theturtle
I've seen the thread and searched many other. I have tried all bleed methods mentioned
Old Nov 20, 2013 | 07:57 AM
dcains's Avatar
dcains
I'm at a loss. Sorry I don't have any more suggestions.
Old Nov 20, 2013 | 08:25 AM
KornerCarver's Avatar
KornerCarver
You might want to consult a professional mechanic. I'm sure the problem can be fixed.
Old Nov 20, 2013 | 08:40 AM
NOLAGG's Avatar
NOLAGG
Honestly this exact thing happened to me and had to pull the transonic to find out the fins on my pressure plate were messed up and needed to replace my pressure plate do that's honestly your best bet, pull the trans .
Old Nov 20, 2013 | 12:06 PM
dcains's Avatar
dcains
Might be a bit drastic, but certainly a possibility. OP, can you see the travel of the clutch fork? If it's moving within spec, then you've got an issue with the clutch itself. I've got an '08, so I'm not sure what your setup looks like.
Old Nov 21, 2013 | 02:45 AM
tony_theturtle
yeah man you were pretty much spot on. i Dropped the trans and found that the bolts from the pressure plate backed themselves out anyways its engaging nice and smooth now thanks!
Old Nov 21, 2013 | 02:51 AM
travlee's Avatar
travlee
Master
assuming they were not torqued down properly if that was the case. who did the work initially?
Old Nov 21, 2013 | 03:12 AM
tony_theturtle
im assuming that what happened. it was done by a shop. i just add some medium strength loctite and torqued to spec
Old Nov 21, 2013 | 03:20 AM
travlee's Avatar
travlee
Master
that sucks, but at least it was something halfway simple
aarrgghh
May 1, 2022 11:04 AM
RyansZ33
Sep 15, 2015 05:54 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Darkspy
Sep 7, 2015 09:09 PM
