Cylinder compression check
Old Nov 23, 2013 | 01:32 PM
raybot's Avatar
raybot
Default Cylinder compression check
I did my compression check today with my 2003 350z and im amaze that it still have 185 psi in all 6 cylinder. I use mobil 1 full synthetic since the day i got it and i change my oil ever 3k miles with k&n oil filter. Also i use a MAG tool compression gauge and 7 rotation for the check, but her is the question? According to what I've research the minimum psi is 142 and the good once is 180-195 psi, how could this happen with my 13 year old car to still have that much of compression or maby it just the gauge that i use.
Old Nov 23, 2013 | 02:53 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Try to replicate the results with someone else--preferably an experienced tech--using a different comp gauge.
Old Nov 24, 2013 | 03:57 AM
Spike100's Avatar
Spike100
Originally Posted by raybot
I did my compression check today with my 2003 350z and im amaze that it still have 185 psi in all 6 cylinder….
…According to what I've research the minimum psi is 142 and the good once is 180-195 psi, how could this happen with my 13 year old car to still have that much of compression or maby [sic] it just the gauge that i use.
Retaining spec compression is related more to the mileage than to the car’s age. My 2003 Z (2003’s are actually 10 years old now, not 13) still has excellent compression.
--Spike
Old Nov 24, 2013 | 06:44 AM
raybot's Avatar
raybot
My bad yes my mistake its only 10 years and about the miles i got a 134k miles on it
Old Nov 24, 2013 | 02:13 PM
Spike100's Avatar
Spike100
If your car has not been abused and the oil/lubricant changed on a reasonable schedule, the engine should be OK and have good compression.
--Spike
Old Nov 24, 2013 | 02:59 PM
raybot's Avatar
raybot
I really hope my test is accurate, because im planning to spray it with 75 wet shot of zex nitrous and uprev tune before summer.
Old Nov 24, 2013 | 06:59 PM
Andrei's Avatar
Andrei
Just don't
Old Nov 24, 2013 | 07:18 PM
NOLAGG's Avatar
NOLAGG
lol
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
