rebuild or replace motor
Old Jan 14, 2014 | 06:08 PM
laser204's Avatar
laser204
Default rebuild or replace motor
hey guys..just looking for ideas,havent made up my mine yet.
i have an 03 base with 80k and she burns oil..its not a big deal but i would really like to fix this and i also would like to supercharge it or turbo.leaning towards the supercharger..
anyways...do i just rebuild my motor or shop around for a performance motor?
now,if i buy a performance motor then i cant supercharge it till next yr,because of funds..
if i just rebuild my motor then theres a possibitly i could juice her up this summer..
what would you guys do???
Old Jan 15, 2014 | 02:43 AM
oldschool350z's Avatar
oldschool350z
I would worry more about fixing or replacement versus adding a turbo or supercharger.
Old Jan 15, 2014 | 03:22 AM
bealljk's Avatar
bealljk
If you think 400whp will be plenty of power than just get it rebuilt locally and add a bolt on supercharger kit. I had the procharger kit on my car for 4 years and it was great, alot of people use the vortex kit as well. Either kit will be fine. If you think you want more than 400whp than you gotta get a built block.
350-425whp = $7k
425-600whp = $15k
600-800whp = $25k
800-1200whp =$40k
Old Jan 15, 2014 | 08:20 AM
oldschool350z
If you want power and since you need a rebuild anyway now is the time to do it... But it will cost you
Old Jan 15, 2014 | 08:38 AM
taywan's Avatar
taywan
I'd leave it alone and just check your oil every week etc. That's semi low mileage for the z so I'd get the best out of that motor and save the money.
Old Jan 15, 2014 | 08:48 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Let's expand on this answer a bit. If your VQ35DE is burning oil, it's most likely a sign of worn rings and a tired bottom end. If you're seriously considering either s/c or turbo, you're only going to stress an already weak link in your Z.
At least the best answers are clear: either spend the money to rebuild the engine and particularly the shortblock, for a forced induction application or not. If you don't have the money to do it right, simply don't do it. I've seen several Z owners spend significant money on FI and either blow it up or suffer terminal engine problems within a year or two.
So save your money until you can do it right and keep adding oil for now...
Old Jan 15, 2014 | 09:35 AM
e30cabrio's Avatar
e30cabrio
This.
Find my threads don't put money into a VQ35DE.
Old Jan 15, 2014 | 03:00 PM
laser204's Avatar
laser204
Default thanks guys
awesome reply's!!! i will bank my money to have a performance motor with a s/c. i guess i could always buy piece by piece till i have everything i need.
i have looked into the LS1 swap..not sure if i wanna go the route. would kinda like to keep it somewhat stock,well with the VQ motor anyways..
thanks for all your input and opinions..
Old Jan 15, 2014 | 03:30 PM
oldschool350z
The vq engine is very reliable, sometimes there are cases where they burn oil and as stated it's the rings generally. It's not like the subarus that have spun bearings which is why a lot of people need to rebuild
I would do what was stated and keep an eye on the oil level.
Old Jan 15, 2014 | 04:31 PM
rich2342's Avatar
rich2342
What are the options for a stock engine rebuild? mine is burning pretty well prob about 1.5 per 2000 miles.
350Z_Al
Oct 29, 2020 07:44 PM
350z82
Oct 1, 2015 06:25 PM
