Replacement spark plug tube gaskets
Old 03-27-2014, 11:59 AM
moheadmobile
moheadmobile's Avatar
Default Replacement spark plug tube gaskets
Good afternoon all. After discovering oil on one of my spark plugs, I'm trying to replace the spark plug tube seals/gaskets/grommets whatever you want to call them.
Okay so I know these seals are built into the valve cover. I just recently discovered the R&D Factory DIY kit containing a set of these seals along with OEM valve cover gaskets and OEM pvc valve gasket...
http://yhst-13387653796039.stores.ya...g35vacore.html
Only problem is, I get an error message when ordering, their contact# goes straight to voicemail and their voice mailbox is full. Can anyone here confirm that they are in fact out of business or what their deal is?
Does anyone here have a part# for just the seals? Or atleast know of a replacement seal that will actually fit and work? I know it's a project requiring a hole saw and plenty of time, I just really don't want to spend $250 replacing a $3 piece.
Someone mentioned part# 13276-31U10 as a replacement. These don't look promising as they are visibly different than the seals used in the R&D DIY guide. Thoughts?
Thanks everyone.
Old 03-27-2014, 12:17 PM
npr350z
npr350z's Avatar
http://www.z1motorsports.com/350_g35...oducts_id=3576
or get the maxima valve cover, crack em open and rip out the seal. then take the baffles off yours and put the new gaskets in.
Old 03-27-2014, 05:10 PM
saywat?
saywat?'s Avatar
don't order from R&d's generic site. nothing but run arounds with that company
Old 05-26-2014, 11:34 PM
R&DFactory
R&D Factory
R&DFactory's Avatar
we are here, we working on the new web, always can call us at 909-287-3511 ext 102 , or email us at info@rndfactory.com , thank you and sorry about this.
Old 05-26-2014, 11:41 PM
R&DFactory
R&D Factory
R&DFactory's Avatar
https://my350z.com/forum/engine/5900...t-is-back.html
the link to our post, it has all info you need to know .
Old 05-27-2014, 05:31 AM
92K1500
92K1500's Avatar
I've heard lots of mention on using seals out of the Maxima cover, but don't pull the baffles off. Use a hole saw like the DIY's show.
Old 05-27-2014, 12:43 PM
R&DFactory
R&D Factory
R&DFactory's Avatar
Old 08-26-2014, 01:58 PM
R&DFactory
R&D Factory
R&DFactory's Avatar
http://www.rndfactory.com/Web/NISSAN-vc%20kit.html
Old 08-27-2014, 09:32 AM
Arsenal350
Arsenal350's Avatar
I bought some altima valve covers from nissanpartsconnection.com removed the baffles and carefully pulled the new seals out then used the holesaw technique to reinstall them. I havnt had it leak since and cost only a fraction of what you would normally pay. Heres a link to the thread I made: https://my350z.com/forum/maintenance...ransplant.html
Old 08-27-2014, 10:08 AM
saywat?
saywat?'s Avatar
idk rnd sells jus the seals for $60.kinda comes out the same as buying Altima covers lol
Old 08-27-2014, 01:28 PM
R&DFactory
R&D Factory
R&DFactory's Avatar
yes you can do that but Nissan is using the same compound so it will end up with same thing when time go's by, we use different compound on our grommets.
Old 04-18-2017, 11:17 AM
octet
octet's Avatar
https://www.torqen.uk/nissan/350z/en...50zderock.html
07-10-2022 07:44 AM
burglapfd
12-06-2020 01:04 PM
11-09-2020 10:27 AM
350z82
10-01-2015 06:25 PM
Quick Reply: Replacement spark plug tube gaskets
