Electronic buzzing from engine bay
Old Apr 24, 2014 | 11:17 AM
AARONHL's Avatar
AARONHL
Default Electronic buzzing from engine bay
Noticed an electronic buzzing from the engine bay. It's consistent not like the fuel injectors, but very similar to that and it can be heard 10 feet or so away from the car. Anyone have a guess with this information? I can't locate the exact area, I know it is coming from front of the car
Old Apr 24, 2014 | 01:58 PM
PerfZ's Avatar
PerfZ
Throttle body if it is bit of a high pitched sound and only when the key is on but motor not running. Perfectly normal.
Old Apr 24, 2014 | 02:27 PM
AARONHL's Avatar
AARONHL
I can hear it with the engine running. I am going to troubleshoot by turning off the AC and stuff... just wierd because I noticed it very recently. My right HID headlight also flickers so maybe it's the light making the noise?
Old Apr 24, 2014 | 03:20 PM
Spike100's Avatar
Spike100
A flickering HID will produce noise.
Old Apr 24, 2014 | 04:56 PM
AARONHL's Avatar
AARONHL
Here is a video- What is this noise coming from? Strange noise coming from engine. You can tell the noise is more pronounced when the camera is moved towards the front wheel well. You can hear it from each wheel well, sounds like it is coming from under the car. Happens at idle after revving the engine a little bit
Old Apr 24, 2014 | 06:08 PM
Stanyer89's Avatar
Stanyer89
Maybe someone installed a supercharger on your car and you didn't notice.
Old Apr 24, 2014 | 06:25 PM
Edmonton 350z's Avatar
Edmonton 350z
Bad ballast in your HID.
Old Apr 24, 2014 | 06:53 PM
verdict.'s Avatar
verdict.
Thread moved to Maintenance & Repair
+1
Old Apr 24, 2014 | 07:33 PM
AARONHL's Avatar
AARONHL
Could be...the right headlight is flickering...But why could I hear it as loud on the left side tire? Seems like revving the engine triggers the sound too
Old Apr 25, 2014 | 12:40 PM
nscheuermann's Avatar
nscheuermann
I have the same issue, makes sense that it could be the ballast because I only hear it when my headlights are on. However, the volume on my head unit also must be greater than 0. Headlights on, head unit at 0, no buzz. Turn up volume, buzz. Any thoughts on that one?
Old Apr 26, 2014 | 02:05 PM
AARONHL's Avatar
AARONHL
It doesn't always stay on I hear it momentarily when I rev up the engine- I hear it slightly once the rpms immediately drop getting off the gas. Such a weird noise
Old Mar 11, 2021 | 12:00 PM
Brianc_55's Avatar
Brianc_55
Did you ever figure out? I’m having this noisy problem with my G
OneLovelyZee
Mar 2, 2014 07:10 AM
importdemon5
Apr 16, 2009 04:40 AM
En-GLaived
Feb 23, 2008 05:49 AM
Twistedframe
May 5, 2004 03:01 PM
Pitlizard
Nov 13, 2003 10:03 AM
