Tranny making weird sounds in 1st-2nd? I have a solution!
Hey everyone,
So I just got back from Nissan and was originally getting new rotors and pads put on. However, given that I had purchased the car used and had no history of the last time any of the fluids were changed, I asked for them to do a multi-point inspection. Prior to all of this, I owned the car for about 8 months and have always noticed a spooling/rotating winding sound with the tranny when entering 1st and going into 2nd gear. I've searched and searched and found many others having related problems. Well any how, I got the results from the inspection and found out my car needed new brake, tranny, and LSD fluid. Obviously I gave them the go ahead to get the car in tip top condition and here were the results...
There is no longer any sound in the transmission when going from 1st to 2nd. It sounds clean as a whistle and quiet for the most part as any regular car should. I left this dealer expecting to have amazing brake response which I did but was even more amazed that I unexpectedly resolved a problem that I have been constantly looking for an answer for.
I apologize if this has been resolved numerous amounts of times, and this is simply another one of those, "We already know this..." threads, but I really wanted to share this with the Z community so they know. However, if this post is pointless and has already been said, Mods please feel free to remove.
Thanks,
Justin
Thanks,
Justin
Nissan put in all synthetic fluids where synthetic could be placed. At the very start of 1st gear (and I mean very very start) you hear the sound up until 1.2K on the tac but then it goes away. Even if you rev 1st gear all the way up to 7.5k, it still doesn't make the sounds as described. And as you would suspect, 2nd gear is clean sounding. Best of luck! Obviously brake fluid doesn't matter with the sound, but I believe the tran fluid change was $199.00. 100% flush with new filters. LSD, I don't believe that has any affect either but I did it anyways because I love my car. (If your car has no LSD, get the LSD synthetic fluid anyways. Better quality)
This post makes an excellent point: changing fluids on a regular basis can make a significant difference to how your Z operates. Even better, it doesn't take that much work to DIY (there are plenty of threads on tranny, diff, etc changes). I find Redline MT85 in the tranny is an excellent product and fits the factory specs for out manual trannys.
BTW Jyoza- there are no filters on your tranny and $200 for a fluid change (2 1/2-3 quarts) sounds pretty expensive to me. Brake fluid can effect the overall function and durability of your braking system. Water collects in the fluid itself, which makes it less effective as the brakes warm, and contributes to master cylinder wear.
The more I use Nissan dealers for service the more I'm finding that the techs and service department in general are composed of a bunch of idiots. I think it may be better to find a reputable private shop for any work as the chances are that the techs at Nissan have never worked on a Z before anyway... This last visit has been ongoing for over two months and I still don't have my car back, plus they left it unlocked and my radio was stolen...
Yikes!! Sounds like Nissan has treated you guys like ****! I don't know! I know my advisor to the point that we walk around and talk about stupid **** when he is on his lunch break. I've had the following done to my car from the same Lynnes Nissan Dealer: Exhaust, Valve Covers, O Rings, Full Brake Job, Oil Change, and now Tranny, LSD, and Brake Fluid. So far so good but I hope this lucky streak doesn't come to an end.
Yea, I'm still fighting with the manager now since the radio was recovered, but will be held for evidence for a few months. OP, I'm glad you're having a good experience with your dealer, wish there was a reputable one near me...
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
