Oil Use
Old Aug 13, 2014 | 03:15 PM
350z4jr's Avatar
350z4jr
Default Oil Use
I have a 2006 Grand Touring Z with about 58k on it. I've been driving back and forth from San Diego to Vegas, about every week. seems it may be burning oil as pressure has dropped from 60 psi to 30-40 psi at same RPM, speed, etc. I switched to synthetic about 12K miles ago...runs much better...
Any thoughts? Is this normal?
Old Aug 13, 2014 | 03:18 PM
Danoman32's Avatar
Danoman32
What do you mean pressure? Oil pressure?
Old Aug 13, 2014 | 03:21 PM
350z4jr's Avatar
350z4jr
Yes oil pressure...after the oil change on the highway it runs right at 60 psi, but slowly after miles, say 6,000 miles it is running at 30-40 psi at same speed, rpm, etc
Old Aug 13, 2014 | 04:11 PM
oldschool350z's Avatar
oldschool350z
That is odd. If it's the same rpm it should be the same. My psi never goes that low when driving always around 60.
Since you have the rev up engine it could be consuming some oil. I would check the oil level and viscosity. Look also to see if it has an odd color
Old Aug 13, 2014 | 04:13 PM
KornerCarver's Avatar
KornerCarver
Do you not check your oil level occasionally?
350z4jr's Avatar
350z4jr
Default Oil Use?
I have a 2006 350Z Grand Touring. I bought it used 2 years ago with 16K on it. It ran std oil evey 3k miles, until 12K miles ago, when I switched to synthetic.
Made a huge difference in pep. It seems it is using about .5 to 1 quart every 6K mile or so...is this standard for the Q V6. My Maxima (2001) went 260K (before it got crashed by my son) and never used a drop.
Just wondering, since after ^K mile pressure drops from an even 60 psi while at cruise to 30-40 psi...THANKS!
350z4jr's Avatar
350z4jr
6k not ^k
Old Aug 13, 2014 | 04:14 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Only way to determine actual oil use is to check the dipstick. How much oil loss is it showing each week?
Old Aug 13, 2014 | 04:17 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Thread merged. We don't need multiple threads to clutter up the site.
Old Aug 13, 2014 | 04:18 PM
350z4jr's Avatar
350z4jr
Thanks for the prompt response...I didn't know about the "rev up" configuration in the Grand Touring...I presume that's a differently tuned Q V6?
Old Aug 13, 2014 | 04:19 PM
350z4jr's Avatar
350z4jr
Thanks, I'll learn proper protocol as I go
Old Aug 13, 2014 | 04:38 PM
350z4jr's Avatar
350z4jr
It's down half a quart after 6000 miles
Old Aug 13, 2014 | 04:39 PM
350z4jr's Avatar
350z4jr
down about 1/2 quart after 6000 miles
Old Aug 14, 2014 | 05:17 AM
KornerCarver
That isn't excessive oil burning. Is your car manual or automatic?
Old Aug 14, 2014 | 05:22 AM
350z4jr's Avatar
350z4jr
6 speed manual
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
