window randomly stopped
Old Aug 14, 2014 | 09:42 AM
Hornlesscow's Avatar
Hornlesscow
Default window randomly stopped
hey guys I went to put my window up and right before it hit the top it just stopped. the weird part is the window feels very loose and I can manage to pull it up the extra 1/4 inch. the window switches make noise when pressed but the window wont move. prior to this the window was secure and the only problem was the motor went down a bit when the window auto up was pressed. Im not sure if its the motor because the window is very loose like I said but I don't know any help?
Old Aug 15, 2014 | 09:36 AM
Danz13's Avatar
Danz13
Im having the same thing happen on my passenger side window. I am replacing the motor this weekend
Old Aug 16, 2014 | 12:01 AM
Hornlesscow
im going to try to take apart the door tomorrow if i get the chance ill let you know if i find a fix without replacing the motor!
Old Aug 16, 2014 | 05:51 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Just read this- my guess is the window regulator has gone out and needs replacing. The question is, do you replace the window motor just to be sure?
Old Aug 16, 2014 | 09:01 AM
oldschool350z's Avatar
oldschool350z
Your window motor is shot. I had to replace mine after this happened.
Always buy oem and they revised the part so it's less prone to break now.
Old Aug 16, 2014 | 01:57 PM
mr. sparco's Avatar
mr. sparco
https://my350z.com/forum/maintenance...dow-motor.html
https://my350z.com/forum/maintenance...-be-fixed.html
Option 2: Replace motor brushes instead of the entire motor.
Old Aug 17, 2014 | 02:41 AM
Hornlesscow
thanks guys, i didnt get a chance to look at it yet hopefully ill be able to tear it apart monday or tuesday, ill update when i get a good look
Old Aug 19, 2014 | 04:41 PM
Hornlesscow
update: finally got around to it and the motor wouldnt spin when i pressed the switch but did when i spun by hand. im not sure exactly which part went because i checked everywhere for "gunk" and i found it was fairly clean where it needs to be. long story short i replaced it but it still does the down an inch everytime i use auto up. so i just need to fix that and get rid of all the duct tape residue
Old Aug 19, 2014 | 04:44 PM
mr. sparco's Avatar
mr. sparco
You didn't HAVE to use duct tape, there are other types of tape out there. lol
Old Aug 19, 2014 | 05:02 PM
oldschool350z
You might also need to reset the window motor.
Old Aug 20, 2014 | 03:47 AM
Hornlesscow
JUST did it, tried the up and down for 10 seconds but that didnt work so i followed the tsb to hold the button, did the trick perfectly!
haha i know man but with my luck anything else would have failed and i didnt want any more expenses lol. a little lacquer thinner and a blade outta do the trick just nicely
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
