350z fuel door wont open.
Old 02-25-2015, 11:02 PM
jonny992
jonny992's Avatar
Default 350z fuel door wont open.
the latch is stuck I think, the flap wont open and im almost on empty. need help asap!!
in the pass I always have to press the button a few times. now its completely stuck. never had this problem before even when it was -20
Old 02-26-2015, 12:23 AM
Jennifer 2
Jennifer 2's Avatar
Since you have had to press the release button multiple times in the past to get the door to open, the best guess would be that the actuator is working, but the door spring is sticking. Stand by the door and have someone press and hold the button. You will hear a click from the door actuator; use your finger or a credit card to gently pop open the door. Look at the plastic arm of the hinge, note how a flat leaf style spring is compressed and slides along the plastic arm to pop open the door. Clean this area and apply some lightweight silicone grease along the plastic arm where the spring contacts it. This made my early model Z’s door behave. There is a stronger spring (your 08 should have this spring) available but I didn’t get it as the lubrication worked so well. If silicone grease (some auto parts stores sell it as dielectric grease) isn’t handy, ask your mom or older sister for a dab of their silicone sex lube, as it will do in a pinch.
If the actuator isn’t clicking, you will have to check fuses and troubleshoot the electrics. If you remove a lot of side trim pieces in the trunk area, you can get at the actuator to remove and test. To open the fuel door there is a white hook on the actuator, pull it and it will release the door latch.
Old 02-26-2015, 11:33 AM
jonny992
jonny992's Avatar
thxs I just poured a bucket of hot water n fixed it. no need for silicone sex lube
Old 02-26-2015, 12:16 PM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
If the electric release will not function at all, there's still a way to manually get to the release. You'll need to get behind the interior panel on the side the fuel door is at. Usually, you have to pull both the rear panel (where the trunk latch is) and then the side panel to reach the release. If you can find it, It's a black rectangular plastic panel and there is a white tab sticking out the back end. Pull that white tab and the fuel door will release.
Old 02-26-2015, 12:34 PM
Jennifer 2
Jennifer 2's Avatar
Jonny992, you have to realize the difference between treating symptoms and fixing problems. Cleaning and lubricating the fuel door hinge/spring is a maintenance item that should be preformed every few years on a Z, because that fuel door design is a bit substandard. And that’s using the kindest language I can think of.
Cars nowadays are full of plastic parts that may stick, squeak and operate roughly. Petroleum based lubricants are not well suited for plastic. Buy a small tube of silicone grease for use on the myriad of plastic and rubber parts in your car.
Old 02-26-2015, 04:41 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
+1 to DK, there is a manual release but you have to remove the truck interior pieces to access...I'll post a pic...
Old 09-26-2019, 12:57 PM
JnBZ
JnBZ's Avatar
Yup...spray lithium grease. Works fine.
Old 09-26-2019, 01:04 PM
travlee
Master
travlee's Avatar
Received 9,059 Likes on 6,523 Posts
4.5 years later......
masterjr33 (09-27-2019)
Old 09-26-2019, 04:29 PM
JnBZ
JnBZ's Avatar
Phuckoff, moron. What’s your problem? Tinypenis? Mommy tell you to get back in the basement?
Old 09-26-2019, 05:22 PM
travlee
Master
travlee's Avatar
Says the idiot with personal attacks
Old 09-26-2019, 06:17 PM
JnBZ
JnBZ's Avatar
O...M...G! You do live in the basement... 38,000+ posts. Get a life.
Old 09-27-2019, 02:47 AM
travlee
Master
travlee's Avatar
you have a short fuse, prob because of other shortcomings you have.... not to mention you live in the ne, so you are most guaranteed to be a complete jersey shore type **** waffle
some fun facts for ya little boy, there are not many basements in texas due to the high clay content of the soil
now lay off the mountain dew and doritos while watching your furry ****, and you might want to cut back the roids some..... you have anger issues
Old 09-27-2019, 02:49 AM
travlee
Master
travlee's Avatar
and if you really are 71, you are a sad sad old man
Old 09-27-2019, 04:55 AM
masterjr33
masterjr33's Avatar
jersey boy is a tard..
Old 09-27-2019, 05:11 AM
travlee
Master
travlee's Avatar
i dont know why he went full retard...
Old 06-06-2023, 05:38 AM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,067 Likes on 755 Posts
My fuel door was sticking and came across this thread.
And then I lol'd at the above posts.
Worthy of a dead thread bump.
Now I'm craving some Mountain Dew and Doritos for some reason.
Old 06-11-2023, 05:41 AM
Escobar
Escobar's Avatar
amazing content here, I just learned how to lube my door and that there are no basements in texas due to soil.
xz350zx
03-21-2014 05:57 PM
SirZaLot
07-31-2009 11:51 AM
thr33fiftyzee
04-05-2008 08:18 AM
tiki240
03-29-2007 12:56 PM
SweatyPalm
10-30-2003 08:41 PM
Quick Reply: 350z fuel door wont open.
