air bag light
Old Apr 3, 2015 | 04:07 PM
350zatx's Avatar
350zatx
Question air bag light
Code is pulling up driver side, side impact sensor open. Anyone run into this? All wires appear to be connected I try not to mess to much with airbags. It doesn't effect car or me passing inspection but hate a blinking light on dash. I can clear with my Mac code scanner but it just comes back. Otherwise the system tests fine.
Thanks in advance
Old Apr 3, 2015 | 04:11 PM
Spike100's Avatar
Spike100
You should get this analyzed/fixed right away. This requires a visit to the dealership.
Old Apr 3, 2015 | 04:17 PM
350zatx's Avatar
350zatx
Or have body shop next to us take a look he does that crap all the time
350zatx's Avatar
350zatx
He thought it might just be a wire I'm missing inside seat wasn't sure if anyone had ever had same issue
Old Apr 3, 2015 | 04:26 PM
Spike100's Avatar
Spike100
Why are you (how could you be) missing a wire inside the seat?
Old Apr 3, 2015 | 04:40 PM
350zatx's Avatar
350zatx
Because it's the sensor for side airbag in the seat. Wiring diagram showed sensor in seat not sure if that's even correct
Old Apr 3, 2015 | 04:49 PM
Spike100's Avatar
Spike100
^^ I would definitely get this solved. --Spike
Old Apr 4, 2015 | 06:18 AM
i8acobra's Avatar
i8acobra
Unless the car has been hit or the sensor/harness has been disturbed (removed from the car, cut, etc...), 95% of the time, it's the diagnostic sensor unit causing the code. It's the metal box in the console with the 3 yellow connectors. If you decide to replace it, be sure the battery is disconnected and only use hand tools, no power tools on the bolts holding it in.
Just thought I'd add this here also... If you ever get a driver's airbag (in the steering wheel) code, it's almost always the spiral cable.
Uriyo_
Sep 8, 2021 08:46 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
