battery disconnects at times
Old Nov 23, 2015 | 07:01 PM
Bak3rme's Avatar
Bak3rme
Default battery disconnects at times
2003 350z
issue: at times when i start my car, i turn the key and all power is lost. i have to go pop my hood and wiggle the positive terminal and then power is restored. My negative terminal is tight, my positive one is a bit loose but i bought a brand new positive terminal connector and it still is loose. The battery is correct size for 350z.
if i tighten the positive terminal all the way it still won't be snug like the negitive terminal.
Old Nov 23, 2015 | 07:03 PM
turboed350z's Avatar
turboed350z
check again...
Old Nov 23, 2015 | 07:11 PM
Bak3rme's Avatar
Bak3rme
Originally Posted by turboed350z
check again...
when i read ur comment i went to go check again. but i cannot tighten down any more its still loose. should i check one more time?
Old Nov 23, 2015 | 07:32 PM
dkmura's Avatar
dkmura
General & DIY Moderator
How old is the battery? Is the positive terminal worn down to a smaller diameter?
Old Nov 23, 2015 | 07:53 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Go to pep boys and get the correct terminal/cable. Worse case, shim the terminal with lead shims.
If you can move the terminal, it's the wrong one.
Old Nov 23, 2015 | 07:55 PM
turboed350z
im going to go out on a limp and say, your connector broke or you have the wrong size connector. you can run to autozone and get oem connector for like 5 bucks.
Old Nov 23, 2015 | 09:01 PM
dcains's Avatar
dcains
http://www.autozone.com/batteries-st...er/257147_0_0/
Old Nov 24, 2015 | 08:23 AM
Bak3rme's Avatar
Bak3rme
battery is 3 years old. i think what you said about the smaller diameter is correct. but shouldn't a battery that fits the Z fit without any issue
good deal i think im gunna get that
Old Nov 24, 2015 | 08:24 AM
Bak3rme's Avatar
Bak3rme
yessir. but i think the diameter of the terminal is too small. im gunna grab a shim
kgman1000
Jul 7, 2020 05:32 PM
sauer420
Aug 27, 2016 06:12 PM
ryanjarosz63
North East Marketplace
Jan 19, 2016 07:47 AM
Rouse350z
Nov 5, 2015 11:46 AM
