need help!
Old Dec 26, 2015 | 11:34 AM
CMarkie's Avatar
CMarkie
Default need help!
i have an 03 350z the issue im having is the engine seems like its running fine however the whole car shakes heaving during idle and while driving. theres also a chugging type sound from the exhaust. ive checked the MAF sensor and the Crank position sensor and the TPS. im at a loss. any help is appreciated.
Old Dec 26, 2015 | 11:58 AM
lowtempo's Avatar
lowtempo
Are you throwing any error codes? check engine light on?
Old Dec 26, 2015 | 12:08 PM
CMarkie's Avatar
CMarkie
Misfire code P0300 and the service engine soon light is on and blinks when
I drive.
Old Dec 26, 2015 | 02:26 PM
guitman32's Avatar
guitman32
Engine is misfiring check your coil packs, common issue.
Old Dec 27, 2015 | 06:31 PM
CMarkie's Avatar
CMarkie
Thanks
Old Dec 29, 2015 | 12:56 PM
Spike100's Avatar
Spike100
^^ I agree with guitman32’s suggestion. Your problem description along with the misfire code suggests a faulty coil pack.
Old Dec 29, 2015 | 03:21 PM
zakmartin's Avatar
zakmartin
Don't go replacing your coil packs until you've tested them first. Unless you LIKE to blow wads of cash.
Also, it would have helped if you had posted your error code in your first post, along with the mileage on your car and any mods or recent work done.
Old Dec 29, 2015 | 03:29 PM
Spike100's Avatar
Spike100
I was surprised how fragile coil packs were after a car had 100k mileage. I tested after having the problem. --Spike
apex locator
Jan 18, 2016 08:42 AM
louisville13
Jan 14, 2016 08:17 PM
Steve Mack
Dec 28, 2015 01:26 PM
andrew.white
Dec 22, 2015 03:22 AM
