350Z radio stays on when car is turned off
Old Jan 9, 2019 | 12:19 PM
cman350z's Avatar
cman350z
Default 350Z radio stays on when car is turned off
Hello guys , my 2003 350Z is stored I discovered when I turned the vehicle off, key out the radio stays on , I have to press power off, this radio has been installed for over a year aftermarket head unit JVC , I ordered a Ignition switch hoping this is the issue , open for suggestions thanks
Old Jan 9, 2019 | 02:16 PM
dkmura's Avatar
dkmura
General & DIY Moderator
If it's an aftermarket headunit that's staying on, it's a problem with the install. I'd focus on that, rather than the ignition switch. Who did the install?
Old Jan 9, 2019 | 03:02 PM
Spike100's Avatar
Spike100
The power wire (probably a red wire) on your H/U is connected to a continuous power wire (probably a yellow wire) and not a switchable IGN wire. Your H/U is drawing power even when the ignition id OFF.
The fix is connecting your H/U power wire to a switchable IGN wire. That is an easy fix. You do not need a new ignition switch.
wolfrain63
Apr 21, 2023 05:37 AM
BelarusesZ
Jun 6, 2017 08:58 AM
jimpactmfsc
Aug 9, 2010 08:26 AM
BiGGD198
Jun 22, 2010 06:49 PM
