2003 350z stalls randomly then runs perfect
Old May 29, 2019 | 04:36 PM
Mschill271's Avatar
Mschill271
Default 2003 350z stalls randomly then runs perfect
I have a 2003 350z touring coupe with auto transmission. The car will just stall. It will stall on the expressways at speed, at a stoplight, under acceleration or idling. It idles smoothly at 650rpm. When it stalls the service engine soon, TCS OFF and SLIP lights comes on. I put car in neutral and start the car all the lights stay on. It starts very hard but starts. When I park the car it will start (easily) only the check engine soon light will be on. I check the codes and they are bank 2 cam position sensor. I have changed both cam position sensors multiple times. The car runs perfect it will cut out for a second then everything works perfect again. I am leaning towards the ECU as I have checked all the outboard sensors
Old May 29, 2019 | 04:54 PM
travlee's Avatar
travlee
Master
OEM sensors?
Old May 29, 2019 | 05:32 PM
Mschill271's Avatar
Mschill271
No aftermarket replaced bank 2with 3 different sensors and bank 1 with 2 sensors
Old May 29, 2019 | 05:59 PM
Spike100's Avatar
Spike100
The problem you describe really sounds like a camshaft sensor failure. I had failure after replacing a camshaft sensor with a non-OEM one. I then installed an OEM sensor I bought at a Nissan dealership, and that worked.
Old May 29, 2019 | 06:24 PM
travlee's Avatar
travlee
Master
Exactly where I was going with this
Old May 29, 2019 | 06:31 PM
Spike100's Avatar
Spike100
Some owners also report they had to replace the crankshaft sensor after replacing a camshaft sensor. I'm not sure why this might be required.
Old May 30, 2019 | 03:26 AM
Mschill271's Avatar
Mschill271
I will give it a try
Old May 30, 2019 | 03:48 AM
travlee's Avatar
travlee
Master
Courtesyparts.com
Old May 30, 2019 | 12:43 PM
WYZIWYG's Avatar
WYZIWYG
Save yourself the headaches now, replace both cams and the crank with the OEM parts.
Old May 30, 2019 | 07:49 PM
Spike100's Avatar
Spike100
That is exactly what I did after attempting a non-OEM camshaft sensor replacement. When this failed, I replaced both camshaft sensors and the crankshaft sensor with new OEM sensors. That fixed it.
Old May 30, 2019 | 09:07 PM
bealljk's Avatar
bealljk
Has anyone suggested the fuel pump? I know non-OEM sensors are no-no but sounds like a fuel pump going out?
Old May 31, 2019 | 06:48 AM
WYZIWYG's Avatar
WYZIWYG
The longer I keep/maintain this car the more temperamentalI realize it can be.
Old May 31, 2019 | 09:02 AM
masterjr33's Avatar
masterjr33
since he is getting camshaft sensor codes. it would be more beneficial to look at those as the failure before going to the fuel pump.
Old May 31, 2019 | 05:48 PM
Mschill271's Avatar
Mschill271
Changed out cam shaft sensors with OEM and issue solved. I have gotten so good at replacing these non OEM sensors I can replace bank 1&2 sensors in less tha 10 minutes each. No need to remove air intake or plenham. Stay away from aftermarket sensors for this motor. It will give you allot of trouble. Thanks for all of your help
Old Jul 29, 2019 | 03:27 PM
Kevin Donahoe's Avatar
Kevin Donahoe
Thanks for the post! (And all the advice shared by others) Having same exact symptoms as you’d describe. Mine has died about half-dozen times in the past few months...and now 3 times in 4 days.
Will follow the wisdom here and do OEM sensors only!
Tool Man
May 30, 2019 09:05 PM
John_B
Oct 1, 2012 07:29 PM
sactownZ916
Jul 5, 2011 01:07 PM
RedlineNismo
Dec 11, 2007 04:33 PM
BhashaZ
Dec 14, 2005 10:26 AM
