Vq35de warm start broblem
Tried to search but didnt find solution...
Ok, car is 350z -04 manual with DE motor. Bought it as a project car and done some maintanance... and now it is back on road again
Car starts perfect when totally cold or "hot". Broblem is, when driven to normal temperature and let to cool down 20-30min, it takes a long to start the car (5-10sec)... It always starts, sputtering few seconds and then start to idle normally.
Recent maintanance ( <100 miles, which would possibly effect this):
-Spark plugs replaced
-Engine grounds cleaned
-Both cats and all o2&af sensors replaced
-intake manifold cleaned & gaskets replaced
-oem pvc replaced
-tb cleaned
-new battery
Otherwise bone stock except k&n intake, kinetix cats, unbranded exhaust. 130k miles. No error codes anymore (had few from old cats/sensors). Otherwise engine works fine, no missfires etc.
Suggestions?
-oem pvc replaced
-tb cleaned
-new battery
Suggestions?
I replaced both cam sensors and crank sensor. No luck
BUT, when i changed new fuel dampeners i noticed that system wont keep fuel pressure at all when engine stopped. So, next is fuel pump, i assume there is leaking non return valve somewhere in fuel pump assembly. Since car is high mileage, going to reolace whole assembly.
New Evap canister & fuel pump assembly (Hitachi), now it starts perfect cold, warm, hot
-evap canister got a quite big hole (!) on side
-fuel pump just old, new one "sounds" better (no loud whine)
carder24
Jan 19, 2025 04:10 PM
