Engine revs and runs fine but car does little movement.
Old Feb 19, 2020 | 02:47 PM
Ghalleo's Avatar
Ghalleo
Default Engine revs and runs fine but car does little movement.
I'm not sure what could be the problem. My car starts fine with no issues. Engine runs fine and doesn't cut out or anything. However, I'll put the car in drive and give it some gas and hear a buzzing sound seemingly coming from the front area of the car but it doesn't move as it should. It seems to never make it out of first gear. I'd be flooring the gas pedal still little to no movement. Going up a hill is impossible. Has anyone experienced this before or knows what could possible be the problem. Please chime in. Thanks. 2005 A/T
Old Feb 19, 2020 | 02:53 PM
travlee's Avatar
travlee
Master
Trans is fooked
Old Feb 19, 2020 | 03:16 PM
dkmura's Avatar
dkmura
General & DIY Moderator
First, pull TCM and ECM codes to determine what's defective. Could also be limp mode...
Old Feb 19, 2020 | 03:59 PM
travlee's Avatar
travlee
Master
Possible.....we shall see
Old Feb 20, 2020 | 07:43 AM
masterjr33's Avatar
masterjr33
You have a charlie sheen problem...
Dead tranny.
Old Feb 20, 2020 | 09:42 PM
calvin.w's Avatar
calvin.w
is there fluid in it?
Old Feb 20, 2020 | 10:34 PM
Ghalleo's Avatar
Ghalleo
Yup it's good on fluid. Fluid doesn't smell weird or anything. Fluid still very pink. I'm totally baffled that the tranny would just crap out. I never drove her hard
Old Feb 21, 2020 | 08:02 AM
jhc's Avatar
jhc
General & Tech Moderator
^^^ This.
Have you been doing 30K transmission services? Btw if the wrong ATF has been used it may resemble transmission failure. If in doubt drain it and refresh with correct fluid. Gl!
AARONHL
Oct 2, 2011 10:46 PM
ghamazy
Jan 20, 2010 10:06 PM
donkinuts
Apr 24, 2009 08:27 AM
Jcolman
Oct 27, 2005 05:40 PM
Z_Coaster
May 27, 2004 05:15 PM
