Overheating
Old Mar 21, 2020 | 09:20 PM
MigV666's Avatar
MigV666
Default Overheating
Hi recently my 2003 350z had a problem with the waterpump. I changed that and since it was a used car i decided to change a few other parts too. Ended up changing the thermostat, temp sensor, and radiator. Then bled out the air and everything ran fine and hot air in cabin at idle. After about 10 minutes of driving i turned on the cold air and the engine temperature went up almost to the top. Put it back on hot air and temp went back down but stayed slightly over half way. Revving wont make it go up just changing the air does. Does that mean theres still air in the system or did i put something in wrong?
Old Mar 22, 2020 | 09:55 AM
dkmura's Avatar
dkmura
General & DIY Moderator
There's still air in the system. Try using a Lisle funnel and a long idle/bleed time.
Old Mar 22, 2020 | 12:00 PM
jhc's Avatar
jhc
General & Tech Moderator
In addition to this solid ^^^ advice, I found it enormously helpful to pull the "Bleeder-valve" in front of the heater core in engine bay and literally pour coolant until all air bubbles are gone. GL!
Old Mar 22, 2020 | 06:49 PM
MigV666's Avatar
MigV666
Awesome thanks guys!
Old Aug 15, 2020 | 01:28 AM
AnthonyC's Avatar
AnthonyC
Default Overheating every minute
hey so I tried bleeding out the coolant and am pretty sure I did it wrong because now every time I turn the car on it over heats in less then a min me and my friend tried getting rid of the air in the engine but it seems impossible I’m thinking of taking it to a mechanic near my house so they could probably bleed it because while I turned the car it sounded like some computer parts broke in the process I’m very worried I’ve done something wrong and completely ****ed my car up over something so small——-please help
Old Aug 15, 2020 | 07:37 AM
JohnSmithington's Avatar
JohnSmithington
Definitely just take the vehicle to a reputable mechanic. You most likely did not **** up your whole car or break any computer parts.
brooklyn
Oct 1, 2017 06:13 PM
fuzzy_dba
Sep 10, 2008 10:34 PM
pdjafari
Oct 13, 2005 06:10 AM
fanatic
Sep 25, 2003 11:23 AM
zmadnez
Sep 17, 2003 08:08 PM
