Greetings, need your assistance
Old Oct 11, 2021 | 02:43 PM
BayouBill's Avatar
BayouBill
Default Greetings, need your assistance
I'm new to the 350Z ownership and this forum.
I bought a 2003 Touring edition from a family member who lives in Reno NV and I drove it back to my home to Louisiana. Great road trip!
After I get home I'm driving around town the next night and I notice I don't have a drivers side Low Beam. It was working OK when I left NV.
I also remember seeing moisture on the inside of the drivers headlight lens the day before and just before I got home from the trip I drove thru a windy driving rain storm so maybe that headlights seal is leaking.
Next, diagnose the problem. (here's the layout before starting) Passenger side works great, high and low beams work. Drivers side, only high beam works.
1st I started with the fuses (checked out OK)
2nd I bought a new HID bulb (new bulb made no difference)
3rd I wanted to swap the ballast from the working light to the non working light to see if I had a blown ballast. I removed the bumper and swapped the ballast (no change) Also tried different bulbs (no change)
OK guys, please tell me what I'm doing wrong. I need to drive the car out of town Thursday night but can't go with no drivers low beam.
I appreciate any and all help, Thanks
Forgot to mention, while testing, I noticed the passenger side low beam also no longer works. So both headlights do not have low beam ...
Old Oct 11, 2021 | 04:33 PM
dkmura's Avatar
dkmura
General & DIY Moderator
How did you check out the headlight relays and fuses? Do you have a FSM to guide you?
Old Oct 11, 2021 | 05:31 PM
Ponyryd's Avatar
Ponyryd
You need to get yourself a wiring diagram and check for your low beam feed and ground, ground is usually shared between the two beams, so it’s likely good, but I’m not sure where the actual feed is from, its likely from the bcm.
Old Oct 12, 2021 | 11:09 AM
BayouBill's Avatar
BayouBill
I found the problem.
It was the Ballast and Igniter
This was my first post, did I post it in the wrong place?
Thanks.
Old Oct 12, 2021 | 11:13 AM
dkmura's Avatar
dkmura
Thanks.
Glad you figured it out. You did fine with your first post and posted in the correct forum for questions like this..
Old Oct 12, 2021 | 02:06 PM
BayouBill's Avatar
BayouBill
Thanks DK :-)
ECLIPSEGST25
May 28, 2017 03:42 AM
Corvett z07
Dec 28, 2016 07:56 PM
FOOKhonda
Jun 22, 2014 09:28 AM
Zmindset
Mar 13, 2014 05:23 AM
WV350z
Apr 3, 2011 06:45 PM
