Clutch pedal problem after sitting 17 months
Old Nov 27, 2022 | 08:44 AM
JCat's Avatar
JCat
Default Clutch pedal problem after sitting 17 months
~ 60,000 miles
After sitting in my heated basement for 17 months, I started her up and noticed immediately that the clutch pedal went straight to the floor. She had no problems before she sat. Pedal does not return without help.
Can sitting or not using the car cause something like this?
The clutch, pressure plate, transmission, and slave were all replaced by Z motorsports about 3 years ago.
ALSO, are some brands of master cylinders and slaves better than others? or Where is the best place to get rebuild kits?
Thanks
Old Nov 27, 2022 | 05:32 PM
i8acobra's Avatar
i8acobra
Seals in the master and or slave are bad due to sitting. Replace them.
Old Nov 28, 2022 | 05:13 AM
Heel Til I Die's Avatar
Heel Til I Die
When I changed mine, I just went with a Centric slave cylinder, since I didn't think there was really anything too fancy about it and it was pretty cheap without having to rebuild it. For the master, I replaced OEM with either Wilwood or Tilton (can't remember which one). I also changed the reservoir so I could use my Motive power bleeder and bleed it by myself without an extra set of hands. I followed these two write-ups:
https://my350z.com/forum/engine-driv...-cylinder.html
https://my350z.com/forum/engine-driv...voir-swap.html
Michael DiBacco
Mar 18, 2020 05:19 AM
sways350
Feb 11, 2018 04:51 PM
cpatel529
Aug 22, 2014 05:57 PM
superspud
Jun 8, 2010 01:23 PM
hackermb
May 21, 2009 12:58 PM
