HELP!!! CAR WONT sTART!!!!
Old Mar 16, 2004 | 01:20 PM
dimitri's Avatar
dimitri
let me know the fix i have the same issue
Old Mar 16, 2004 | 02:45 PM
KPierson's Avatar
KPierson
Where about in Philly are you? I"m in the Philly area and would be willing to help troubleshoot this problem. I'm staying by the airport in Essington.... Let me know!
Kevin
Old Mar 16, 2004 | 02:54 PM
jesseenglish's Avatar
jesseenglish
Originally posted by the O.Z.
What would anything to do with a stereo install have anything to do with any of this anyway? That is what I am getting at. If someone could tell me what could possibly cause this... I could just fix it myself.
Well if you really want to troubleshoot it down yourself, you're going to have to figure out what exactly is failing. Do you have an Oscillosope and a copy of the FSM? If so you can find out exactly what portion of the engine isn't working and troubleshoot it from there. If more than one thing is failing, you can figure out what they have in common and fix that.
Monitor, injector pulses and coil trigger signal to find out which isn't working and work backwards according to the FSM. Without some equipment and seeing what's going on we're all just shooting in the dark.
With a only a multimeter you can figure out many things too though. Obviously as most have mentioned, fuses are the easiest and first thing to check. However there are several fusible links in the engine wiring that could have melted. Continuity checks between the various wires on the injectors/coilpacks/MAF/crank angle sensor and their outputs from the ECU would help you troubleshoot it down. Although it's a tedious process, that is what's next if you're absolutely sure it's not the fuses or fusible links. BTW, there are fuses at more than one location in our car.
Other things you can check with a multimeter might be.
voltages to the fuel pump.
Voltages on the coil pack connector
Voltage on the fuel injector connector.
Sorry for the long post, but without actually seeing the car, it's hard to troubleshoot over the internet.
Old Mar 16, 2004 | 05:21 PM
the O.Z.'s Avatar
the O.Z.
thanks for the post... I appreciate the response. I have checked everything I can think of with the multimeter including those mentioned above. I am very good with cars usually. I have rebuilt cars from the ground up. This one has be stumped though... and it must have service stumped as well... they have had my car since sunday and they can't tell me what is wrong yet. I was hoping to point THEM in the right direction.
Vince
Old Mar 18, 2004 | 01:03 PM
the O.Z.'s Avatar
the O.Z.
Vince
So here is the latest update. They say its a bad ECM. Which is what I told them to begin with. They said the part is back order for at least 2 weeks. They have already had the car for a week... this is BS!!!!! I'm so mad I don't know what to do with myself.
Old Mar 18, 2004 | 01:14 PM
dimitri's Avatar
dimitri
cant they get the part from another dealer?or why dont you call a couple different dealers to find out if they have it. I hope that helps man iam waiting also to find out my problem also.
Old Mar 18, 2004 | 01:28 PM
the O.Z.'s Avatar
the O.Z.
They claim to have already checked with other dealerships. I may do some searching this evening.
Old Apr 5, 2004 | 07:20 PM
ZxRage's Avatar
ZxRage
Any updates? When you say a bad ECM, do you mean the ECU? I am interested to see how everthing turns out for you.
aarrgghh
May 1, 2022 11:04 AM
Ronso
Oct 30, 2015 12:39 PM
OdesiTT
Sep 30, 2015 10:47 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
