Rear Hatch Opening Fix
Old Dec 13, 2006 | 04:03 PM
  #101
SweetDreamZ's Avatar
SweetDreamZ
does it improve performance if you don't go cheap, and use 3 dimes on each side
Old Dec 14, 2006 | 01:50 PM
  #102
Sean_350z's Avatar
Sean_350z
and here I thought it was some stupid security thing that you had to pop it twice. Luckily I've only put up w/ this for a couple weeks (just got the car). I'll be doing this fix. Thanks!
For those wanting more than the 2 penny pressure but less than the 3 penny pressure here's how many coins to drop in.... (yeah....I've got calipers at my desk and I'm bored. LOL)
2 pennies - 2.92mm
3 pennies - 4.46mm
2 nickels - 3.80mm
1 penny & 1 nickel - 3.41mm
Old Mar 30, 2007 | 06:06 AM
  #103
Apexi350z's Avatar
Apexi350z
Charter Member #50
my 2 pennies each side trick doesn't work anymore. so I tried 3 pennies, still need to double click remote to lift the hatch.. need to find another solution.
Does the dealer still fix TSB if the car is out of warranty?
Old Mar 30, 2007 | 06:10 AM
  #104
TheVoreHouse's Avatar
TheVoreHouse
Just keep putting in more pennies. I had to use 4 each side to get mine up.
Old Mar 30, 2007 | 07:06 AM
  #105
Ed 718's Avatar
Ed 718
BRAVEHEART
You can damage the hatch with so many pennies you will possilby dent the hatch. If you read the thread someone did do damage to it but it's not my car.
Old Mar 30, 2007 | 07:57 AM
  #106
jtabraham's Avatar
jtabraham
I made the mistake of putting too many pennies in. 5 on each side, and I was greeted with a nice little ding on each side of the hatch.
Old Jul 26, 2007 | 09:40 AM
  #107
Ed 718's Avatar
Ed 718
BRAVEHEART
Bump -
For those who missed this thread...........
Old Jul 26, 2007 | 10:19 AM
  #108
PikesPeakZ's Avatar
PikesPeakZ
Getting mine replaced by the dealer for free today.
http://www.nissanhelp.com/Ownership/.../NTB04-042.htm
Here is the link for the TSB
Also if you are interested for the fuel door:
http://www.nissanhelp.com/Ownership/...NTB04-059.htm\
Good luck
Old Aug 20, 2007 | 07:13 AM
  #109
doctorshumes's Avatar
doctorshumes
NismoV2 spoiler is very heavy. Got tired of listening to the hatch noise while going down the road, having to hit the pop button 2-3 times and having the hatch hit me in the head. Ordered the heavyduty hatch struts which only fixed the hitting me in the head part. 2 pennies, didnt touch it, 3...no, 4...no 5....no. It took 6 freaking pennies on both sides to get it to pop open. Of course there is a little dent in the hatch now and unfortunately now I have to hit the pop button twice again. Need stronger springs from somewhere. I wonder if the furniture end covers some have used would work better. ANy ideas for those with spoilers??
Old Aug 20, 2007 | 06:44 PM
  #110
DukeEntDotCom's Avatar
DukeEntDotCom
blah
works like a charm...thanks!
Old Aug 21, 2007 | 06:41 AM
  #111
edvy's Avatar
edvy
doctorshumes, did you try to remove the 4-5lbs counter weight inside your hatch door. it should be easiler for you to open your hatch after.
Old Aug 27, 2007 | 12:23 PM
  #112
jgregory124's Avatar
jgregory124
great idea
Old Sep 15, 2007 | 11:46 PM
  #113
sim012's Avatar
sim012
help I lost the damn sping for the right side. anyone know the part number or where I can order one for cheap... thnks I really need it guys
Old Sep 16, 2007 | 04:36 PM
  #114
Sean_350z's Avatar
Sean_350z
parts dept at dealer maybe?
Old Sep 20, 2007 | 06:25 AM
  #115
jutnismo350z's Avatar
jutnismo350z
Dreamz n Motion
I have been trying to find an affordable solution to this pop lid problem for about a year. I can not believe it only took 4 cents to fix the problem. DOES ANYONE HAVE THE THREAD ON HOW TO TAKE THE WEIGHTS OFF THE DECK..for when i install my Nismo Spoiler....
Old Apr 2, 2008 | 06:02 PM
  #116
hiz-n-herz's Avatar
hiz-n-herz
This is the thread that keeps on giving.. Awesome...
Just had a nismo V1 JDM spoiler installed on my wife's car and had the dreaded 2-click, 2-handed release. $.20 later and no problems
I went with the 4-nickel finish for that ballin' action.
Old Apr 2, 2008 | 06:16 PM
  #117
zstreet86's Avatar
zstreet86
dang i can't believe i never found this thread!!!, im going to try it as soon as i get off work. ive been doing the double click and lift for quite some time now after the addition of my nismo spooiler... very clever i must say
Old Apr 2, 2008 | 06:25 PM
  #118
snaponbrian's Avatar
snaponbrian
hiz-n-herz: I went with the 4-nickel finish for that ballin' action.
lol ...I will take this approach
I have had my 03 for a few months and it only started this recently weird
Old Nov 6, 2008 | 09:03 PM
  #119
myhosilver's Avatar
myhosilver
thank you so much!
Old Nov 7, 2008 | 11:19 AM
  #120
cantfindaname's Avatar
cantfindaname
I am not discounting the OP at all, this is very good advice (I used it 4 penny trick for 2 years) but if your hatch ALWAYS takes 2 pushes of the button to open (or if you have to lift immediately after pressing the button) then you need to just go ahead and replace the stock lifts.
This is even more valid for those of you with any type of spoiler.
As soon as I replaced my lifts, the hatch popped up several inches.
Once again, I am not taking anything away from the OP, just wanted to let people know that in most cases, its not the spring that is the issue, its the lifts.
