Rear Hatch Opening Fix
Old Dec 23, 2008 | 08:49 AM
  #121
mumbles6's Avatar
mumbles6
I can't believe I waited 2.5 years to do this easy mod!
Old Dec 23, 2008 | 07:43 PM
  #122
XtwoZ's Avatar
XtwoZ
best trick ever
Old Jan 21, 2009 | 04:58 AM
  #123
MandalynsZed's Avatar
MandalynsZed
Wow that 4 pennies thing works! And so easy. I did it all myself and I'm a girl.
Old Jan 28, 2009 | 01:39 PM
  #124
Toby-22's Avatar
Toby-22
Yep did this yesterday and it worked great. Very helpful thread!
Old Jan 28, 2009 | 05:05 PM
  #125
Ed 718's Avatar
Ed 718
BRAVEHEART
Wait don't put four pennies per side or the hatch will get dented.I used only two pennies per side for a total of four.
Old Jan 28, 2009 | 05:26 PM
  #126
tnk210's Avatar
tnk210
Randomly stumbled upon this thread. Just fixed my '03 hatch problem!
Old Jan 31, 2009 | 06:03 PM
  #127
BaZooKa's Avatar
BaZooKa
i LOL'd when i finished mine ,, just did it and was so great ,, i removed my rear wiper last month so i could open the hatch easier ,,
but the 4 cent thing is more effective
Old Apr 23, 2009 | 04:25 PM
  #128
driftmc's Avatar
driftmc
I was working on something else on the car, but then I remembered reading about this and I've had the hatch problem too,
so I gave it a try, 2 minutes & 4 cents later, my hatch opens with only a single try! Just the way it is supposed to be
Awesome write up!
Old Apr 23, 2009 | 07:43 PM
  #129
Ed 718's Avatar
Ed 718
BRAVEHEART
Good thing you guys still use this simple trick, Glad I could help.
Old Apr 23, 2009 | 11:35 PM
  #130
quakerroatmeal's Avatar
quakerroatmeal
Doesn't work for mines.
Old Jun 24, 2009 | 10:42 AM
  #131
LehighGuy's Avatar
LehighGuy
Can we get a repost of the TSB? The link in the previous posts of this thread doesn't seem to take me to the right place - I get sent to an infiniti site. Thanks.
Old Jun 24, 2009 | 09:31 PM
  #132
zeruck's Avatar
zeruck
Originally Posted by cantfindaname
I am not discounting the OP at all, this is very good advice (I used it 4 penny trick for 2 years) but if your hatch ALWAYS takes 2 pushes of the button to open (or if you have to lift immediately after pressing the button) then you need to just go ahead and replace the stock lifts.
This is even more valid for those of you with any type of spoiler.
As soon as I replaced my lifts, the hatch popped up several inches.
Once again, I am not taking anything away from the OP, just wanted to let people know that in most cases, its not the spring that is the issue, its the lifts.
I just had the hatch struts replaced by the dealer, and I still need to push the button 2 times for hatch to open completely so obviously I disagree.
6 years I have lived with this problem, first thing in the morning I will try your solution. Thanks in advance Ed 718 and HokieZ.
Old Jun 25, 2009 | 05:23 AM
  #133
quakerroatmeal
Anybody know where to get brand new spring lifts for cheap? courtesy nissan says its likes 30$ a piece. I might just fork up the dang cash if I can't find one at the junkyard off a new z.
Old Jun 25, 2009 | 12:01 PM
  #134
zeruck's Avatar
zeruck
Nissanparts2u.com seems to have the best prices for new oem parts. Most dealers will match price. $25.60 for lift gate spring.
Old Jun 25, 2009 | 02:43 PM
  #135
Eddie@Performance's Avatar
Eddie@Performance
Performance Nissan
Finally a use for those darn pennies in your ashtray haha, good work.
Old Jun 26, 2009 | 05:55 AM
  #136
quakerroatmeal
Still a bit much, I can't even find it on nissanparts2u
Old Jun 26, 2009 | 06:19 AM
  #137
JasonZ-YA's Avatar
JasonZ-YA
Ok,.....i read through this thread and thought to help answer some questions posted lately on the design of the rear hatch, i have studied the hatch on the Z closely and have done calculations and all.........used aerospace digital push /pull gauges and all, made load charts....etc..
Spring poppers - are responsible for opening the hatch.
Lift/hatch shocks - are responsible for assisted/lifting the hatch once popped open and the hatch is lifted by hand at least a few inches (8 inches normally) the lift shocks will take over.
2 pennies is the magic number........1 nickel and 1 penny is a bit of an upgrade.....but once the springs weaken (which will happen at some point) the springs will need to be replaced, However the penny trick does buy you a good amount of time......more pennies, etc will lead to a dented hatch area.....depending on the spring strength still....
I have worked and installed different hatch shocks! and only when you go way high in force does the hatch shocks start to help the spring poppers......in turn installing very strong hatch shocks makes the hatch hard to close, it takes both hands and a bit of might to get it down......So its not by design at all for the hatch shocks to help pop the hatch, but strong enough ones will aid the poppers..
So the hatch shocks themselves are NOT to help pop the hatch open, thats the sole intention and design of the failing poppers....
your best bet is to try the penny trick and depending on the stage of wear your springs have, you may or may not get some results.
if you have any other questions.....pm me......
-J
Old Jun 26, 2009 | 08:06 AM
  #138
Eddie@Performance
Performance Nissan
We have them for $23.04 for the newest revised model. Part# 84415-CD71A
Old Jun 26, 2009 | 08:39 AM
  #139
quakerroatmeal
Eddie is that for a pair or 1 (needing two total)e? Shipped as well?
Old Jun 26, 2009 | 08:50 AM
  #140
Eddie@Performance
Performance Nissan
That is for each one unfortunately. Shipping is like $3 if that. (With in USA)
