ChriZTT's Pikes Peak White 350Z Build Thread
Old Mar 7, 2015 | 03:21 PM
  #101
ChriZTT's Avatar
ChriZTT
Originally Posted by sofa king
good **** dude
Thanks! I'm really liking the new wheel setup on your S14. Can't go wrong with TE's.
Old May 3, 2015 | 10:37 AM
  #102
ChriZTT's Avatar
ChriZTT
So I want to document a few small changes that have taken place since I last updated the thread.
I went ahead and neatly tucked away and secured the exposed wiring harness that was behind the driver's seat.
Before:
After:
I also did some finishing work on the cubby covers. I was originally going to paint them black, but I've fallen in love with the look of the bare aluminum. So I brush finished them by hand.
Picture does not have the best quality, but I think you can somewhat see the grain in the aluminum.
Next on the short list is the harness and ARP extended wheel studs. Both should make for a fun couple of hours in the garage.
Old May 3, 2015 | 10:43 AM
  #103
zstreet86's Avatar
zstreet86
I agree aluminum covers look best.
Old May 3, 2015 | 05:38 PM
  #104
NA&CH's Avatar
NA&CH
Yea we are going to have to do this on mine I can help with ARP
Chris
Old May 4, 2015 | 10:34 AM
  #105
Osmar350zHR's Avatar
Osmar350zHR
wow great job...looks so clean
Old May 16, 2015 | 10:21 AM
  #106
ChriZTT's Avatar
ChriZTT
Chris
My first thought was "Chris is sponsored by ARP?" You rocking extended wheel studs on the Z? BTW I'm anxiesoulys awaiting for you to post some ZdayZ photos!
Thanks Omar!
Old May 16, 2015 | 10:38 AM
  #107
ChriZTT's Avatar
ChriZTT
So this happened last weekend... Looks like the Z is getting a 1JZ!
Just kidding This 1JZ belongs to an '88 Supra owned by a buddy of mine. The bottom end is getting overhauled so I helped him pull it out in his driveway. Good times lol.
With all the love I've been showing the interior of my car lately I figured I'd post some crappy iphone pictures of the exterior.
Old May 18, 2015 | 12:10 AM
  #108
KingBaby's Avatar
KingBaby
Hardest Setting
got me lol...
Nice update !
Old May 21, 2015 | 03:07 PM
  #109
Godfoot's Avatar
Godfoot
Wow!!! you have really done an excellent Job!! Great Thread. Can't wait to see more!!!!
Old May 27, 2015 | 06:13 PM
  #110
NA&CH's Avatar
NA&CH
Thanks Omar!
No way man I can help open the beers etc hahaha Its a fun project.
I didn't take any pics from Zdayz Really upset. I was haing clutch issues which put a damper on it. But no excuse.
I did find I need more room behind my seats
Chris
Old Jun 13, 2015 | 10:45 AM
  #111
ChriZTT's Avatar
ChriZTT
Thank you! It's always nice to read comments like this!
Chris
Damn Chris, sorry to hear about the misfortune at Zdayz. I was looking forward to seeing some pictures. Hopefully you still got to do a bit of driving while you where up there.
Old Jun 13, 2015 | 10:46 AM
  #112
ChriZTT's Avatar
ChriZTT
Talking ARP and Schroth Racing
This update marks the end of a chapter in my build. I’ve managed to tie up all the ends and I’m happy to say the car is complete (for now, of course).
This past weekend I completed the install of my ARP extended wheel studs on both the front and rear axels, and also installed my Schroth 6 point harness.
The wheel stud install was simple and straight forward, but as I’ve come to learn over the years of working on cars - Murphy’s Law… In short, I damaged a few threads on the first ARP stud I pulled through the hub. Made a simple correction and had zero issues with the remaining studs. Later (and more importantly), when I went to thread on my lug nuts (which are open-ended R40's) I found that I could not fully thread the R40 lug onto the ARP stud. Why? Because when open-ended lugs that are longer and fully threaded like the R40’s are used with the short OE studs, not all of the threads on the longer lug are being used. These unused threads (on an open ended lug nut) are thus exposed to the elements and over a period of time develop surface rust (aka corrosion). An extended stud will need to use these now corroded threads on the lug in order to completely thread through the lug and fully tighten.
So rather than force the lugs on the new ARP studs I went ahead and order a tap and a die in 12M x 1.25. I used the tap to completely clean out the threads inside of the lugs, and I used the die to fix the threads on that one ARP bolt I slightly hacked up. It worked beautifully!
Front axle Before:
Front axle After:
Stud size comparison: OE vs ARP:
Rear axle After:
All done!
Next up was the harness. After a bit of research the choice was simple. I decided on Schroth Racing and their Profi II-6 model.
Toughest part of the install was figuring out and measuring the anchoring points for the sub belts. One look at the Z’s uneven floorboard and you’ll know why. Measured 100 times and drilled once.
I prepped the backing plates with a scuff pad and then coated then with paint.
I sealed the backing plate with RTV for added protection and installed them.
BuddyClub seat bracket installed:
And lastly a small little teaser until I can take some better pictures.
Thanks.
File Type: jpg
Old Jun 13, 2015 | 11:14 AM
  #113
nizmo_0385's Avatar
nizmo_0385
Great execution!
Old Jun 13, 2015 | 04:26 PM
  #114
KingBaby's Avatar
KingBaby
Hardest Setting
Awesome as always
Old Jun 20, 2015 | 04:27 AM
  #115
QuintonC's Avatar
QuintonC
Wow. This is an amazing thread. Well done!!
Old Jun 23, 2015 | 08:08 AM
  #116
NA&CH's Avatar
NA&CH
So what is your schedule for a shave job?? on the car...
Chris
Old Jun 23, 2015 | 08:21 AM
  #117
jhc's Avatar
jhc
General & Tech Moderator
Nice work, love the car and the tc 105n s.
Old Jun 24, 2015 | 04:01 PM
  #118
pyshin's Avatar
pyshin
Lookin' good, big guy.
Old Jul 1, 2015 | 10:20 AM
  #119
pfregeolle's Avatar
pfregeolle
Wow, how am I just now coming across this thread. Your build is awesome dude, and love the interior work you did. I was hoping to do something very similar with mine in the future.
Sub'd for future updates!
Old Jul 9, 2015 | 03:07 PM
  #120
Godfoot's Avatar
Godfoot
Just now saw this update, Wow!! Looking great!!! Love it!
