Performance Factorys 15 to 1 compression All Motor Project..
Old Mar 27, 2007 | 06:38 PM
  #181
Julian@MRC's Avatar
Julian@MRC
Jeremy, nice work man..
Old Mar 27, 2007 | 07:30 PM
  #182
DRIFT ZZ's Avatar
DRIFT ZZ
I just want to thank Jeremy for his promp delivery of my HKS Hi-power Ti's and Tein Springs today, and MOST OF ALL, TO HEAR AND SMELL THE C16 RUNNING IN THE NA MONSTER MOTOR TODAY !! WOW, THE MOTOR SOUNDS INCREDIBLE JEREMY, CONGRATS AGAIN !!
Hughie...in PSL, FL
Old Mar 27, 2007 | 09:13 PM
  #183
Audible Mayhem's Avatar
Audible Mayhem
My350z
Default FIRST DYNOs!!!
ok, first of all, it started right up!! i am very happy with how it sounds and runs, so WTF, why not break it in on the dyno?? hehehe
here are a couple of the first pulls. this is still stock headers, stock lower runners, stock plenum, stock airbox and tube, mild cams and not tuned. i just did a couple pulls on the dyno to make sure the AFR was safe and took some timing out to be sure...
more to come soon!!!
remember, this is on a dynojet in FL at about 80 degree weather with about two hours of breaking in before hand, this is seriously just the beginning...
Notice how it pulls straight across from 6250 on, i have the rev limiter at 7500 for now...
Old Mar 27, 2007 | 09:19 PM
  #184
Fluid1's Avatar
Fluid1
Originally Posted by EM-EFER
Iam guessing ...........289WHP
Go play the lottery. Right now!!!!!
Nice numbers.......will be watching.
Old Mar 27, 2007 | 09:22 PM
  #185
Sean's Avatar
Sean
grats, hurry and change cams
  #186
GolfinZ's Avatar
GolfinZ
WOW...awesome job Jeremy! Thats a guaranteed 300rwhp Z with headers/tp, spacer/plenum/intake and a tune.
Old Mar 27, 2007 | 09:23 PM
  #187
MI 35th's Avatar
MI 35th
OGPremierMafia
I am happy to see this so close to the 300whp mark. I have no doubt that with the right cams, headers, tune and cosworth plenum it will be well over 300whp.
Old Mar 27, 2007 | 09:48 PM
  #188
IP05G35's Avatar
IP05G35
Those are STD numbers though, SAE will be lower... but yea with some bolt ons it will be over 300 SAE. A bone stock 98 LS1 makes 300hp at the wheels SAE through an automatic. But it won't rev to 7500rpm which is obviously cooler.
Old Mar 27, 2007 | 09:50 PM
  #189
Zexy's Avatar
Zexy
With some wicked cams and headers you should see some jaw dropping power gains jeremy. Looking good!
Old Mar 27, 2007 | 09:54 PM
  #190
Mc556's Avatar
Mc556
Cams, head work and the other required mods and this thing has a lot more than I think everyone might realize... Heads and cams are a must though.. I think that we will see 350whp or more with all of these done plus tune(maybe alot more). Add a 200 shot and with the trans brake I'm thinking low low 10sec ET's maybe high 9's. Jermey whats your car weigh? I'm hoping when my turbo 331 SB is finished I can make it down to Orlando and see this thing run.
Old Mar 27, 2007 | 11:41 PM
  #191
rkd350z's Avatar
rkd350z
very great.
Old Mar 28, 2007 | 02:59 AM
  #192
jksstar's Avatar
jksstar
looking good man
after a few more miles put on it and a tune it should be making some good power. Nothing beats a good N/A powerband, look how smooth it is
Old Mar 28, 2007 | 03:07 AM
  #193
KPierson's Avatar
KPierson
congrats.
Old Mar 28, 2007 | 03:21 AM
  #194
Alberto's Avatar
Alberto
Cranky FI Owner
Great initial dyno's, it has soooo much more left in it man.
Old Mar 28, 2007 | 03:48 AM
  #195
EM-EFER's Avatar
EM-EFER
Thumbs up
What do I win??????
Old Mar 28, 2007 | 03:55 AM
  #196
QuicksilverZ33's Avatar
QuicksilverZ33
lookin good!
Old Mar 28, 2007 | 04:05 AM
  #197
Audible Mayhem
My350z
yeah guys, the motor was very heat soaked, the temps of the coolant stay down pretty well though, just the motor was hot.
i waited about 10 minutes between a pull with the same map and it made 8 more hp.
there is definitely a lot more in it, the heads are fully done btw , i think the car is starving for air though now, i pulled out the k n n filter on back to back runs, on the second run with the filter out, it made 4 more hp with nothing done.
i will be changing it over to a map sensor and speed density so it puts the same fuel settings in every time and doest do a factory off set with the utec.
time to go play some more, i have to tune a few cars today, tomorrow and friday, so i wont have much more time with my car till this weekend
im taking donations on WILD cams and long tube headers where is tomei when i need them??
Old Mar 28, 2007 | 04:08 AM
  #198
Audible Mayhem
My350z
car weighs in at 2500 without me in it, thats still with stock doors, hood, rear hatch and all glass fully caged...
should go 11s all motor without a doubt
here is the same chart SAE, it puts down about 8 less hp.
i think i will go do some pulls this morning when its a bit colder.
Attached Thumbnails Performance Factorys 15 to 1 compression All Motor Project..-jeremy-na-sae.jpg
Old Mar 28, 2007 | 04:30 AM
  #199
aalzuhair's Avatar
aalzuhair
Nice work man on the engine and best of luck
Could you please explain how did you manage to make you car weigh 2500?
Thanks,
Az
Old Mar 28, 2007 | 04:42 AM
  #200
03BrickyardZ's Avatar
03BrickyardZ
Originally Posted by Audible Mayhem
tons of cars run high compression with nitrous all the time. maybe not as wide spread in the import scene though.
its fun doing stuff that hasnt been done before..
The issue is mainly heat... the final cylinder pressure is about the same as an 8.5:1 running 11 lbs.
And nitrous comes out cold. So in this case, a big shot may help.
And I disagree about the cams. If he's spinning to 8500, the best case scenario I think would be cams that are conservative on the intake side and agressive on the exhaust side. That would keep VE down and help keep that engine in one piece.
Just one nerds opinion, though.
