Performance Factorys 15 to 1 compression All Motor Project..
Old Mar 28, 2007 | 05:04 AM
  #201
03BrickyardZ's Avatar
03BrickyardZ
Originally Posted by Hydrazine
I'm sure you already know Jeremy but with a 400 shot, it will only take one ping to occur for flames, pistons and oil to be shooting all over the place.
Subscribing for Vids....
I can help out in the plenum mod dept. LMK.
You know, it might actually be beneficial for your application to use a water/meth injection kit.
There can be several benefits.
1) The obvious, it will help supress the tendancy for ping.
2) You may find you can use a lower octane gas thus reducing the really high fuel costs.
3) It will keep the cylinders, pistons, heads and valves carbon free and very clean. The biggest benefit of cleanliness will be when you shoot the N2O. It would be a lot safer doing a 400 shot into clean cylinders.
It may just be the difference needed for relibility when using a 400 shot.
Hmmmm.... I wish I knew more about methanol. I do know it goes in cold, which would be a biiiig plus with that compression ratio.
Originally Posted by techcontrol
Did you use clay to measure for interference? Running HC pistons/ high lift cams it's a requirement.
thats really pretty clever.
Originally Posted by Audible Mayhem
ok, first of all, it started right up!! i am very happy with how it sounds and runs, so WTF, why not break it in on the dyno?? hehehe
here are a couple of the first pulls. this is still stock headers, stock lower runners, stock plenum, stock airbox and tube, mild cams and not tuned. i just did a couple pulls on the dyno to make sure the AFR was safe and took some timing out to be sure...
more to come soon!!!
remember, this is on a dynojet in FL at about 80 degree weather with about two hours of breaking in before hand, this is seriously just the beginning...
Notice how it pulls straight across from 6250 on, i have the rev limiter at 7500 for now...
Very nice. This thing has a lot more potential.
I'm betting you'll get a big gain out of some good headers... Getting the exhaust velocity up will really improve TQ across the powerband.
Old Mar 28, 2007 | 05:38 AM
  #202
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
It'll be over 300 once it breaks in the rings.
Just drive it 1000 miles and your there.
Old Mar 28, 2007 | 06:25 AM
  #203
RebelinRI's Avatar
RebelinRI
Damn Jeremy. I use to think that you were nuts, but now I know!!! Can someone pass me a towel? Yeah again! Good Luck man. Can't wait to see what she's really got in her!
Old Mar 28, 2007 | 06:40 AM
  #204
roncfpz's Avatar
roncfpz
Awesome Jeremy!
Old Mar 28, 2007 | 08:35 AM
  #205
NA&CH's Avatar
NA&CH
Thats awesome JT. Let me get some cams, headers, and all the good ole' stuff in there and see some numbers.
Congrats on the build.
Chris
Old Mar 28, 2007 | 10:13 AM
  #206
98intrigue's Avatar
98intrigue
You weren't kidding when you said "Wanna race?", were you? Impressive! I need to stop by next week to see this.
Old Mar 28, 2007 | 10:46 AM
  #207
roncfpz's Avatar
roncfpz
im taking donations on WILD cams and long tube headers where is tomei when i need them??
Hmmmmm, sounds like I need to finish your return.
Old Mar 28, 2007 | 10:53 AM
  #208
Lakelandkev's Avatar
Lakelandkev
Wow that's all I gota say....Jeremy that fantastic man. I hope when u hit the track your going to let us know I'll make the drive over from LKLD..
Ohhh Matt thanks for the response thought I seen a clutch pack in the pics...
Someone get a sound clip to post for everyone to hear??????
Old Mar 28, 2007 | 11:16 AM
  #209
MyV6IsFast3r's Avatar
MyV6IsFast3r
Jeremy Jeremy he's our man, if he can't do it, no one can.....
Can't wait to see you at ZDays. Hope your coming again this year. You said you would tune my UTec remember?
Old Mar 28, 2007 | 11:21 AM
  #210
RBlover69's Avatar
RBlover69
Major props man, nothing is like a NA beast. Jeremy your own your way to a NA vq surpassing the 300rhwp mark man. Talk about setting the bar over here in the south east man.
Old Mar 28, 2007 | 11:49 AM
  #211
Audible Mayhem's Avatar
Audible Mayhem
My350z
thanks guys, i figured with my clearance of the pistons and the valves, the smaller conservative cams would be a good start...
i did a pull to 7800 today!!!! hehehe then i ran out of gas damn it
i will post up the graph later on, it pulls straight all the way till i let off the gas, i cant wait to fully tune it and get some nice headers on there.
i need a set of crawfords headers i think. anyone have any for sale.
thanks!!
Old Mar 28, 2007 | 11:55 AM
  #212
Fluid1's Avatar
Fluid1
Originally Posted by 03BrickyardZ
The issue is mainly heat... the final cylinder pressure is about the same as an 8.5:1 running 11 lbs.
And nitrous comes out cold. So in this case, a big shot may help.
And I disagree about the cams. If he's spinning to 8500, the best case scenario I think would be cams that are conservative on the intake side and agressive on the exhaust side. That would keep VE down and help keep that engine in one piece.
Just one nerds opinion, though.
How cold does nitrous come out, when you are heating it over 98* to get the correct pressure?
Old Mar 28, 2007 | 12:39 PM
  #213
ZLadie2000's Avatar
ZLadie2000
Wow, can't believe I missed this. Somebody get this man some Crawford headers and some good cams. Congrats Jeremy!! When you taking it to the track?
I'm thinking about going all NA on my HR motor...that would be a first and be very sweet. Maybe some Nitrous as well! I'm sure Performance Factory can help me with that!
Old Mar 28, 2007 | 12:42 PM
  #214
dvo's Avatar
dvo
wow. those pistons are beautiful
Old Mar 28, 2007 | 12:48 PM
  #215
plumpzz's Avatar
plumpzz
A good set of cams shine with a good set of headers. With an X pipe exhaust, long tube headers, straight pipes and good cams Im sure you can easily hit 350whp (mid 11's on slicks at ur race weight!)
Old Mar 28, 2007 | 12:59 PM
  #216
rkd350z's Avatar
rkd350z
more dynos!!!! can't wait!!!!
Old Mar 28, 2007 | 01:08 PM
  #217
Enron Exec's Avatar
Enron Exec
Wow 2500 lbs? What did you pull out of the car?
Old Mar 28, 2007 | 01:53 PM
  #218
Old School's Avatar
Old School
Shift_Boost
WTG jeremy.... hurry up and tune that bad boy with some long headers and get out to the track. I wanna see you hit 10s all motor. 2500lbs....you can do it!!!
Old Mar 28, 2007 | 02:41 PM
  #219
Hydrazine's Avatar
Hydrazine
boiling point at atmospheric pressure -88.46 oC
Old Mar 28, 2007 | 03:18 PM
  #220
Audible Mayhem
My350z
i need a rev up lower plenum as well, i forgot i need to a
