NA Build Inside....Soup to Nuts :)
Old Jul 13, 2009 | 09:19 PM
  #821
NismoaltSE-R's Avatar
NismoaltSE-R
so anything new happen yet? lol
Old Jul 14, 2009 | 04:27 AM
  #822
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
nope
Old Jul 25, 2009 | 01:14 PM
  #823
Z1 Performance
Former Sponsor
Just figured I'd post an update since I've got some time on my hands today
First, I decided not to pursue the ITB project anymore. The reason? They vary, but suffice it to say, I simply decided to go in a different direction and keep things simpler. I never really had a chance to test it out either, but oh well. It sucks to have lost so much time and money in the process, but we live and learn.
So, here is what I am going with now - Cosworth manifold, 75mm BBK throttle body. The reason for this throttle body and not going back to stock are out of convenience. In setting up the car for the ITB's, I had converted to a cable throttle, flashed the ecu accordinly, and moved some pins around on the Haltech to use the sensor on the gas pedal itself as my TPS. Convering everything back to drive by wire is just another time consuming thing, and time at this point, and I'm tired of waiting. I basically have not driven the car since last December as we trecked through the ITB project. I miss her! I want to use it, and this is the easiest way to go IMHO. Plus, gives us more stuff to test, a cool byproduct. This stuff is already in hand and up with my machinist making the necessary adapter plate. He also is doing some clearning up of the Cosworth manifold to port match it to the lower collector. The flow bench #'s we got from this thing were insane, and with the rpm's I running, it should, in theory, give me some very nice gains up top, without affecting anything down low. I'm really eager to try it out! We'll end up making our own intake pipe to match. Not sure what filter I am doing yet. I'll cross that bridge when I have to. I think I will probably have the Cosworth, the lower collector and the intake pipe all ceramic coated, just to give it all a uniform appearance, and help insulate against heat at the same time.
Interior wise, I hope to get the Rackpak cluster back in my hands soon. I am really looking forward to seeing how it turns out. In my head, it looks amazing, and with the quality of work our interior/stereo guru turns out, I am sure it will meet my expectations. I have not seen anyone fully replace the factory cluster yet with such a piece, except on full out race cars, so it will be cool to see how everything integrates. Thankfully the guy doing the tuning on my car also has alot of experience with these type of dash systems, so I think I'll be in good hands getting it all setup.
Edit - well, just got some pics of the dash
More pics - check the blog!
The rear! The 4.3 rear is finally coming together, and I hope to have it back here in the not-too-distant-future. Definitely a bastard child of a setup, as it's a mix match of parts that were never designed to go together in the first place. I don't see it being viable to "sell" as a setup, because the amount of labor is just insane, and you would really need a pretty high rpm engine to make it worthwhile. But, I'll try to share some pics of the guts and post them on our blog so people can see what is involved in making it all come together. I'm going to be using a Quaife LSD on this setup, and the gears are being micropolished, and cryo'd, all near bearings/hardware throughout. Everything is also blueprinted as well. Should be a pretty trick setup I think. Once it's all running, I'll sit down and analyze costs and if someone is really serious, perhaps it's something we can offer.
That's the latest right now...more to follow as I finally get back behind the wheel! Hopefully sooner rather than later
Old Jul 25, 2009 | 01:40 PM
  #824
03threefiftyz's Avatar
03threefiftyz
Holy Jeebus 4.3FD. I am still debating if I want to bite the bullet for the 4.08's. Hope to see it up and running soon.
Old Jul 25, 2009 | 02:08 PM
  #825
OCG35's Avatar
OCG35
Nice update! I’m very intrigued by the micro polished and cryo’d gears – might be overkill for NA power, but very interesting nonetheless. The ceramic-coated lower collector is interesting as well, possibly the next best thing to Tony’s potential phenolic lower collector.
What rev limit do you anticipate and what did you do internally for failsafe? (it might have been covered earlier, so please pardon me asking if it has)…
I look forward to your completion.
Old Jul 25, 2009 | 02:22 PM
  #826
Z1 Performance
Former Sponsor
rev limiter has always been at 8400 - I don't anticipate raising it, unless the dyno shows me something I'm not expecting. To get it higher would really require new cams (I think), and I'm just not at the point where I've maxed these out yet.
Old Jul 25, 2009 | 06:54 PM
  #827
XM 1's Avatar
nice to see things coming together....even although you canceled the ITB...would have sound badass for sure dashboard came out pretty awesome btw
Old Jul 25, 2009 | 07:29 PM
  #828
gabe3d's Avatar
gabe3d
Good to see that everything is finally coming together and that you will have her back on the road soon. Very curious to see how your manifold and sensor will turn out. Good luck as always and that cluster is looking wicked!
Old Jul 25, 2009 | 07:35 PM
  #829
Resolute's Avatar
Resolute
Thanks for the updates, I'm looking forward to what you get from the TB and Cosworth. Since you're port matching to the lower intake, have you also thought about polishing the Cosworth runners and lower intake passages?
Will
Old Jul 26, 2009 | 03:54 AM
  #830
CarlosCh's Avatar
CarlosCh
Racepak dash... WANT!!!
That is going to look awesome, Adam, congrats!
Old Jul 26, 2009 | 08:20 AM
  #831
Z1 Performance
Former Sponsor
Will
we're just doing basic clean up on it, removing some casting flaws, etc. It flowed almost perfectly right out of the box, and it will support way more cfm, and way more velocity than we could ever hope to achieve.
you don't want to polish the intake tracts smoothly anyway - doing so kills velocity. I trust my machinist..he hasn't let me down yet, and he has all the cool tools to make things come out better than they went in
Old Jul 26, 2009 | 11:04 AM
  #832
Resolute's Avatar
Resolute
I misrepresented myself- polishing was a poor choice of word. I wasn't thinking of a smooth polish to the inside of the runners, but of an extrude hone to remove the casting ridge along the runners, and it sounds as though your machinist will be doing essentially the same task by hand. However, thinking about an actual polish makes me wonder if polishing the bell mouth of the trumpet wouldn't improve velocity into the runner.
Would you mind disclosing how you came to choose a 70mm TB diameter?
Will
Old Jul 26, 2009 | 12:34 PM
  #833
Z1 Performance
Former Sponsor
once I get the plenum back in my hands I'll snap some pics and post them on the blog
75mm throttle body
70mm would be smaller than stock
few reasons - first, Cosworth clearly designed their plenum around a stock, or nearly stock sized throttle body. The flange on it will only accept a unit that is so big. If you try oversizing the unit beyond that point (cutting the flange off and remaking one) you then start upsetting the flow balance side to side and the velocity inside the unit. They did their homework on this piece, so I just wanted to figure out what they did it as they did, and work within those confines. The 75mm units are readily available, not particularly expensive, and had a lever setup on the butterfly that would allow us to easily install the cable.
Old Jul 26, 2009 | 01:31 PM
  #834
Z1 Performance
Former Sponsor
new pic of the cluster progress...factory trim ring installed
should have it back in my hands this week....then I get to worry about getting it installed and setup
Old Jul 26, 2009 | 01:47 PM
  #835
Chef-J's Avatar
Chef-J
Booooosstt!!
That's so unique.
Old Jul 26, 2009 | 02:05 PM
  #836
Kwame's Avatar
Kwame
I'm digging the Viagra post-it in the background...
Old Jul 26, 2009 | 03:27 PM
  #837
Z1 Performance
Former Sponsor
lol - I noticed that too
Old Jul 26, 2009 | 04:20 PM
  #838
Chebosto's Avatar
Chebosto
thats so awesome..
what color are you going to paint it. or are you gonna wrap it in CF?
Old Jul 26, 2009 | 06:21 PM
  #839
Chef-J's Avatar
Chef-J
Booooosstt!!
i missed that!
Old Jul 27, 2009 | 02:19 AM
  #840
Z1 Performance
Former Sponsor
Originally Posted by Chebosto
thats so awesome..
I don't understand the whole carbon wrapping thing to be honest, just not my thing.
Not sure yet on the color...I'll let my installer pick what he thinks will look the best and we'll go from there. If we need to try a few different finishes, at least it's easy to change
