the_coupe's NA build cp manley bc
Old Aug 5, 2011 | 09:09 AM
  #321
the_coupe's Avatar
the_coupe
well. yesterday it made no noise. this morning, however, it did rattle for a couple seconds. but when i left for lunch, it made no noise. idk.......
Old Aug 5, 2011 | 12:03 PM
  #322
mgrotel's Avatar
mgrotel
wtf man?! is performance affected at all that you can tell?
Old Aug 5, 2011 | 12:12 PM
  #323
e30cabrio's Avatar
e30cabrio
Insane. Hopefully it goes away.
Sorry.
Old Aug 5, 2011 | 04:18 PM
  #324
the_coupe's Avatar
the_coupe
nope. still sounds and drives fast and loud. lol
it didnt make any noise when i left work, BUT i did hear a different noise for about a minute. sounded almost like an exhaust rattle, but idk where it was coming from. clutch noise? i might put it on the rack and take a peek tomorrow to see if i can pinpoint that cuz i never noticed it before.
this thing is gonna haunt me....i can feel it :/
when i first tore it apart
with ALL NEW timing chains, tensioners and guides!!!
oh yeah, and the 2 extra pieces i found on the oil strainer :/
Old Aug 5, 2011 | 05:02 PM
  #325
mgrotel's Avatar
mgrotel
I'm wondering if another squirter piece his just chillin somewhere and makes noise sometimes
Old Aug 6, 2011 | 07:50 AM
  #326
Zazz93's Avatar
Zazz93
Probably what got the tensioner...
Old Aug 6, 2011 | 08:01 AM
  #327
e30cabrio's Avatar
e30cabrio
Glad I deleted my squirters. Hope that is all and it's all good now.
Old Aug 6, 2011 | 08:58 AM
  #328
mgrotel's Avatar
mgrotel
You said nothing was contacting the squirters when you were turning the crank by hand?
Old Aug 6, 2011 | 10:26 AM
  #329
the_coupe's Avatar
the_coupe
Yeah it spun over smoothly when i first put the bottom end together. Idk what caused it but i dont really care. Lol. And there was no sign of any metal debris in the tensioner screens either.
Old Aug 6, 2011 | 01:48 PM
  #330
mgrotel's Avatar
mgrotel
So it just at cold startup now? Now I'm worried about my squirters
Old Aug 6, 2011 | 04:28 PM
  #331
the_coupe's Avatar
the_coupe
well just check them out once you put the bottom end together and spint it over. but the pistons you're running dont hardly have a skirt so you shouldnt have a problem anyways.
and yes, it did it this morning again but it isnt super loud and bad sounding giving a weird idle for a few seconds like it was. just a lil rattle for a couple seconds and gone. but didnt do it the rest of the day. lol only thing left in the equation are the sprockets
Old Aug 6, 2011 | 04:35 PM
  #332
e30cabrio's Avatar
e30cabrio
Please please tell me it can't be the sprockets. They are $ so I did not get new ones (my old motor has < 25k)
Old Aug 6, 2011 | 04:52 PM
  #333
1cockyZ's Avatar
1cockyZ
The vvt pulleys are made to retain some oil pressure, the sound you are hearing is the pulley dry starting. Toyotas have this issue as well. Look up dr vanos for the bmws to get a better idea of pulley failure
Old Aug 6, 2011 | 07:30 PM
  #334
mgrotel's Avatar
mgrotel
Are the toyotas just at cold startup too?
Old Aug 6, 2011 | 07:32 PM
  #335
mgrotel's Avatar
mgrotel
Coupe, what oil filter are you using? I always get one with an anti-drain back valve to keep as much oil in the motor as I possibly can. I know its a longshot but I'm brainstorming here, I hate to see someone spend all that money and have problems
Old Aug 7, 2011 | 08:55 AM
  #336
the_coupe's Avatar
the_coupe
Always had an oem nisan 9e filter on it. Im gonna put mobil1 oil in it and oreillys has a special with mobil1 oil and filter for $33 so ill try that and see if it makes a diff.
Old Aug 7, 2011 | 10:18 AM
  #337
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
You have no choice with your crank
Oil squirters are there for a reason. Hopefully what you're hearing isn't the sound of something loose. Have you played with different oils yet? Not that it will solve what seems like a mechanical issue but might help pinpoint it
Old Aug 7, 2011 | 03:30 PM
  #338
the_coupe's Avatar
the_coupe
well its definitely a oil pressure related deal in the timing area. only thing original now are the vtc sprockets.
so far ive been running 5w30 conventional oil...changed it like 3-4 times since new with no debris or anything in the oil. im going to change it tuesday and put mobil1 5w30 in along with a mobil1 oil filter and see if there is any difference.
on another note, im considering getting rid of the car and picking up a y34 m45 now
Old Aug 7, 2011 | 03:33 PM
  #339
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Wanna swap engines with me before you sell it?
Old Aug 7, 2011 | 03:47 PM
  #340
e30cabrio's Avatar
e30cabrio
I am aware of both of those things. Many many people are running the stroker crank without squirters without issue. I am positive BC did their homework before making the crank and am also confident that the improvements to cooling I am doing (bigger aluminum radiator, higher pressure cap, cooler thermostat pathfinder cooling mod & oil cooler) will make up for any lost cooling blocking off the squirters causes.
M45 is quite a U turn!
WTF?
