the_coupe's NA build cp manley bc
Old Jul 12, 2011 | 07:51 AM
  #261
the_coupe's Avatar
the_coupe
i built the motor
yes i put all new oem tensioners on
all of the lifters were within factory specs (i had to change 2 out)
ive changed my oil 2x so far and only have 1200 miles or so on the engine
hop is mexican
and the vid was in the 70s, but it was humid as hell and obviously had rained over night. its a condensation type of smoke, doesnt smell like oil or fuel, and goes away after a couple minutes when it warms up. but i havent noticed it smoking much during cold starts so it must have been the temp/humidity of that morning.
ill try 10w-30 and see if it helps.....might do it today after work.
Old Jul 12, 2011 | 09:24 AM
  #262
Zazz93's Avatar
Zazz93
Dont trip too much on the condensation from cold startups mine is pretty much the same. I waited about 3k to switch over to synethetics to make sure I got a decent ring seal/seat with the clearences piston/ring maker suggested.
How's your oil pressure? Maybe a missed or damaged o-ring.
Old Jul 12, 2011 | 09:51 AM
  #263
the_coupe's Avatar
the_coupe
yeah im not worried about it although i do get a lil smoke when im on decel from high revs. otherwise it does good so idk....
havent checked......ill hook a gauge up to it and see tho
Old Jul 14, 2011 | 06:11 AM
  #264
the_coupe's Avatar
the_coupe
changed the oil with 10w30 tuesday evening. still makes some noise but hasnt been as loud or bad sounding. but i ordered a new primary t-chain tensioner and it came in today so i might put it in today after work....
Old Jul 14, 2011 | 06:58 AM
  #265
mgrotel's Avatar
mgrotel
Does the Oem Nissan filter have a drainback valve in it?
Old Jul 14, 2011 | 01:01 PM
  #266
the_coupe's Avatar
the_coupe
idk....i change these things out on a regular basis and never had a prolem due to an oil filter.
ill change the tensioner out tomorrow after work and see if that was the problem. im startin to think the noise is happening from me having the heads resurfaced.....
Old Jul 14, 2011 | 05:08 PM
  #267
e30cabrio's Avatar
e30cabrio
Did you get head gaskets that accounted for the amount of material that was removed?
Old Jul 14, 2011 | 07:12 PM
  #268
the_coupe's Avatar
the_coupe
you should be able to answer your own question if you followed this thread
but no, im running HR headgaskets
either way, new tensioner will be installed soon...hopefully tomorrow if i get the time.
Old Jul 14, 2011 | 07:15 PM
  #269
e30cabrio's Avatar
e30cabrio
I did not commit every detail to memory & I was just trying to help.
Old Jul 15, 2011 | 12:09 PM
  #270
Classy's Avatar
Classy
when you take off the access cover for the main timing chain cover, which way is the little tab pointing? I am pretty sure it needs to be pointing up, if it isn't it won't be working right
Old Jul 15, 2011 | 01:20 PM
  #271
mgrotel's Avatar
mgrotel
Originally Posted by the_coupe
no real updates, but i finally uploaded a video of the notorious t-chain rattle i have when the car sits for a couple hours. quality sounds bad being so close to the engine but you can hear the rattle when i first start it up.
right now i have cheap advance auto 5w-30 conventional oil and a oem nissan filter. will try some name brand 10w-30 and a wix filter shortly to see if the thicker oil will help. gonna wait til i hit near 3k miles before i switch to synthetic oil tho.
http://www.youtube.com/watch?v=jx00GulwRNo
that sounds bad, almost like a fan hitting something, but obviously thats not it. idk man
Old Jul 16, 2011 | 08:26 AM
  #272
the_coupe's Avatar
the_coupe
sorry e30, did not mean to make it sound like i was bein an ***. just sayin i've repeated everything i have installed more than once im sure and i have nothing special or custom made in this build. i sowwys. forgive?
yeah, it sounds not so delightful. the 10w30 didnt help much. there is very minimal lifter noise and that is not what i am referring to. the vid makes it sound worse than it really is....im just talking about the first initial start and rattle noise for a second or two.
on the other hand, i just put in the new tensioner. idk if this was causing the problem but the spring lock part was broken. i had to push the tab down twice the amount plus some to get the lock to open so i could push the plunger back in. did a lil rattle when i started it back up but thats with a new tensioner. we will see in a couple hours
and ill have pix of the old and new tensioners to show what im talking about, but im at the shop right now so no can do pix right naowww k? k. bye guyz
Old Jul 16, 2011 | 02:53 PM
  #273
e30cabrio's Avatar
e30cabrio
Nothing to forgive, I was just asking.
I remember you used an HR gasket but they come in differing thickness to make up for removal of material.
I hope you find your noise soon.
Old Jul 16, 2011 | 03:21 PM
  #274
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Factory HR headgaskets come in 1 size - you cant remove much material from either the block or heads, as nothing else would end up fitting (timing chain etc). You have a max spec each of the block and heads can be resurfaced to. Beyond that level, those repsective parts must be replaced. Same thickness as all previous DE headgaskets too
hopefully the tensioner fixes the issue
Old Jul 16, 2011 | 03:37 PM
  #275
e30cabrio's Avatar
e30cabrio
When I bought my HG I was offered differing thickness. I assumed the same was available for HR sorry.
Old Jul 16, 2011 | 06:59 PM
  #276
the_coupe's Avatar
the_coupe
oem headgaskets only come in one standard thickness. and from what "I" checked and measured....the HR headgaskets are thinner than the DE gaskets.
so i havent started the car up again since i put the new tensioner on, so i'll check it out tomorrow and see if that remedied my noise concern.
some pix tho.....
put on some new rubber in the rear. this time i got all matching tires 245/35 nexens.
and some custom bracing for the headers.
old tensioner...you see where the tab is way more forward than its supposed to be?
new tensioner...note tab placement
Old Jul 17, 2011 | 12:44 AM
  #277
mgrotel's Avatar
mgrotel
I'm sure that was it then, good find
Old Jul 17, 2011 | 05:10 AM
  #278
Z1 Performance
Former Sponsor
Only Cometic gaskets come in different thicknesses
OEM only come 1 way. All are the same thickness, IIRC it's .63"
Old Jul 17, 2011 | 06:02 AM
  #279
0jiggy0's Avatar
0jiggy0
I bet it was the tensioner. Good job finding it quick. From experience with vq30s I remember sometimes it takes a while for oil to fill the tensioner. Hopefully nothing else was damaged. That tensioner was really extended.
Old Jul 17, 2011 | 09:01 AM
  #280
the_coupe's Avatar
the_coupe
welp, it still makes the noise
