my turn
Old Feb 16, 2012 | 12:34 PM
  #261
mgrotel's Avatar
mgrotel
id be happy with 7200, i think the cutout will help
Old Feb 16, 2012 | 01:54 PM
  #262
0jiggy0's Avatar
0jiggy0
Originally Posted by mgrotel
yea, ill check it. if it is low, i guess i need a new oil pump then???
Thats the number one suspect, but other reasons can cause it. IT's more then worth the piece of mind.
Old Feb 17, 2012 | 07:07 AM
  #263
mgrotel's Avatar
mgrotel
raised the idle with cipher and added 2* of timing. havent heard the rattle anymore so thats good i guess
Old Feb 17, 2012 | 07:08 AM
  #264
mgrotel's Avatar
mgrotel
im gonna be sooooo pissed off if that oil pump is bad, that is not an easy part to replace
Old Feb 17, 2012 | 10:10 AM
  #265
Classy's Avatar
Classy
You will make your power from cam phasing
Old Feb 18, 2012 | 12:32 PM
  #266
mgrotel's Avatar
mgrotel
well, from what ive read, the min oil pressure at idle is consdered 14psi, please advise if that is incorrect. i finally measured oil pressure on my car, and it seems fine to me, here are some pics and the associated rpms
startup, about 1200-1300 rpm: 37psi
adjust idle with cipher to allow it to go back down to 650rpm: 22psi
then used cipher again to have it idle at 900rpm: 28psi
Old Feb 18, 2012 | 03:15 PM
  #267
Classy's Avatar
Classy
yup, you are good, my car was down to 20 ish psi at idle until the motor broken in well. Then it went to a healthy 35psi
Old Feb 18, 2012 | 08:17 PM
  #268
mgrotel's Avatar
mgrotel
It fluctuated that much???
Old Feb 18, 2012 | 09:36 PM
  #269
Zazz93's Avatar
Zazz93
That's good, as for the noise, I know many of the timing chain tensioners seem to get noisy after they are pull off. Not sure why, but I know mine is a little noisy as well, but it clears up as soon as the oil pressure gets high enough.
Old Feb 20, 2012 | 10:18 AM
  #270
mgrotel's Avatar
mgrotel
So I guess I'll just raise the idle and not worry about it since it goes away with rpm
Old Feb 21, 2012 | 02:07 AM
  #271
0jiggy0's Avatar
0jiggy0
Oil pressure changes for various reason. Good readings, piece of mind is a good thing.
Old Feb 21, 2012 | 06:39 AM
  #272
mgrotel's Avatar
mgrotel
yea, i was pretty happy to see those numbers, so i guess i just wont worry about that terrible rattle and leave the idle high enough
Old Feb 21, 2012 | 01:42 PM
  #273
mgrotel's Avatar
mgrotel
so, the guy that assembled the block recommended just conventional oil, but i wanted to run synthetic through it to clean things out some, plus i ran can of seafoam through it too for a few miles. you guys think i should stay with synthetic or go to conventional oil?
Old Feb 21, 2012 | 02:35 PM
  #274
kacz07's Avatar
kacz07
Synthetic 5w40 all the way.
Old Feb 21, 2012 | 10:33 PM
  #275
bjmax's Avatar
bjmax
Back again.. see you made some progress.. thats a good thing oil pressure looking good.. did you changed all the ruber oil rings between the chain tentioners and the block?
Old Feb 22, 2012 | 04:58 AM
  #276
denchan350gt's Avatar
denchan350gt
Why just wondering?
Old Feb 22, 2012 | 06:09 AM
  #277
mgrotel's Avatar
mgrotel
i cant remember specifically, but i had a master gasket set, and replaced orings and gaskets whereever the factory service manual said to, so im sure i did.
where did the_coupe go? i think it might be the same issue he had, loud at startup but then fine once oil builds pressure
Old Feb 22, 2012 | 07:01 AM
  #278
kacz07's Avatar
kacz07
Originally Posted by denchan350gt
Why just wondering?
Higher shearing capacity is better for higher rpms and hard working engines. IPP recommended as high as 10w60 for my built motor built through them.
I have had a few turbos and I see a lot of other turbos running it, too.
Old Feb 22, 2012 | 08:34 AM
  #279
mgrotel's Avatar
mgrotel
that high of weight doesnt mess with the vct solenoids at all?
Old Feb 22, 2012 | 08:54 AM
  #280
kacz07's Avatar
kacz07
German Castrol acts like a 5w40 based on testing.
10w60 may be too high, though. I'll be updating my thread soon.
