my turn
Old Jun 4, 2012 | 03:42 PM
  #361
mgrotel's Avatar
mgrotel
So you removed the whole front timing cover to replace it?
Old Jun 4, 2012 | 04:18 PM
  #362
Classy's Avatar
Classy
You have too... You can't get that sprocket out without doing it, and retiming everything is a lot easier with the cover off. It took a few hours with everything, it isn't that bad of a job compared to some to the stuff with the engine
Old Jun 4, 2012 | 08:01 PM
  #363
mgrotel's Avatar
mgrotel
son of a *****, that isnt what i wanted to hear, lol
im so sick of it all honestly
Old Jun 5, 2012 | 05:44 AM
  #364
Classy's Avatar
Classy
That is why I sold mine, I got sick of the VQ motors
Old Jun 5, 2012 | 05:49 AM
  #365
kacz07's Avatar
kacz07
I replaced my passenger side sprocket, etc. because that is what failed. How did you know it was your driver's side? The car runs wells and was messed up when the passenger side failed.
Old Jun 5, 2012 | 05:55 AM
  #366
e30cabrio's Avatar
e30cabrio
Sorry you are having issues. It is possible to get these dialed in, mine is running perfectly. (hopefully oc won't return)
Old Jun 5, 2012 | 06:21 AM
  #367
mgrotel's Avatar
mgrotel
i know it is the drivers side for a couple reasons, first i am getting a p0011 code which is the drivers side cam advance, and second i logged data with cipher and the drivers side is not advancing properly with throttle like the passenger side is. maybe this will also fix the rattle on cold starts
Old Jun 5, 2012 | 06:45 AM
  #368
str8dum1's Avatar
str8dum1
mine does all that as well. I'm prolly gonna replace the pulley this winter. gotta decide if I want the Nismo ones though. 50* of advance would prolly gain me 40 or 50 more whp thru my midrange.
Old Jun 5, 2012 | 08:11 AM
  #369
mgrotel's Avatar
mgrotel
will the nismo ones just bolt onto a de motor? work with my nonrev de ecu and everything? obviously it would be in the tune to advance that much, but is the capability there with the nonrev de ecu?
and about the midrange, mine is painfully slow right now especially with a high stall converter. if almost feels like compression is low and im waiting for a turbo to spool.
str8dum, have you logged data and you are also not advancing on the drivers b1 side?
Old Jun 5, 2012 | 08:59 AM
  #370
Classy's Avatar
Classy
The nismo ones gave me questions, like of I installed one would say 30 degrees of advance on a stock gear be more at the same pressure that the solenoid pushes out?? I could see that being a large issue if you don't tune it asap
Old Jun 5, 2012 | 10:36 AM
  #371
str8dum1's Avatar
str8dum1
it advances but is very noisy (in terms to how stably it holds the advance). i need to put a scope on the wires before I do anything else.
the pulleys bolt right on. THe stock pullleys are mechanically limited to 40*, not oil pressure. I'd imagine the pressure/degree advance is the same. These just let you tell the computer to run the solenoid more to let them advance further.
Old Jun 5, 2012 | 10:41 AM
  #372
kacz07's Avatar
kacz07
How far can you advance them safely, though? That's what held me back when I ran into my issues.
Old Jun 5, 2012 | 02:37 PM
  #373
mgrotel's Avatar
mgrotel
should i scope my wires probably before i tear into vtc pulley replacement when the motor is in the car?
and is there anything else i should try before i replace it?
Old Jun 5, 2012 | 02:39 PM
  #374
mgrotel's Avatar
mgrotel
or is there ANY WAY to verify for sure that the vtc solenoid is the root cause of the issue?
Old Jun 5, 2012 | 02:44 PM
  #375
mgrotel's Avatar
mgrotel
classy,
did you need to take any coolant hoses off to change it?
did you need to pull the valve covers to time it again?
im guessing so
Old Jun 5, 2012 | 04:04 PM
  #376
Classy's Avatar
Classy
I did not pull the valve covers, I ended up pulling the radiator completely out to use a pulley puller to get my ati pulley off
Timing was really easy, I remember doing it pretty fast
I remember pulling the alternator and power steering was the biggest pain in the butt
Old Jun 5, 2012 | 04:20 PM
  #377
str8dum1's Avatar
str8dum1
i would def scope the cam sensor as well as the IVT solenoid.
make sure the IVT solenoid is getting the signal and make sure that the cam sensor is reading the position properly.
Old Jun 5, 2012 | 05:41 PM
  #378
mgrotel's Avatar
mgrotel
what do you mean by scope, just check voltage?
Old Jun 5, 2012 | 05:54 PM
  #379
mgrotel's Avatar
mgrotel
classy, how did you determine that the vtc sprocket was the problem for sure before you replaced it?
Old Jun 5, 2012 | 07:06 PM
  #380
Classy's Avatar
Classy
It wasn't advancing/retarding, the wires from the ecu to the solenoid checked out, we swapped out a new solenoid, swapped ecu's and nothing changed, I am not sure what else we could have checked
