my turn
Old Feb 2, 2012 | 05:44 PM
  #121
rich2342's Avatar
rich2342
^ Please no. I want to results..
Old Feb 3, 2012 | 08:06 AM
  #122
mgrotel's Avatar
mgrotel
haha, i promise the car isnt sold, if i want another one i will just buy another one as all of my cars are paid off, but i cant justify having 4 cars, so ill stay with three. working on the exhaust now, hoping to start it this weekend.
sorry for the cloudy pic, it gets like that with a flash. ill get a better one later when i can open the garage door after it warms up a little outside
Old Feb 3, 2012 | 12:05 PM
  #123
mgrotel's Avatar
mgrotel
my new breather setup
Old Feb 3, 2012 | 12:06 PM
  #124
mgrotel's Avatar
mgrotel
Old Feb 3, 2012 | 06:37 PM
  #125
johnwigs's Avatar
johnwigs
OMG there is so many things going wrong with this... timing chain timed wrong, and now a giant air leak in the form of fresh air breather...
Old Feb 3, 2012 | 10:15 PM
  #126
mgrotel's Avatar
mgrotel
What makes you say it's timed wrong and where is my leak?
Old Feb 3, 2012 | 11:59 PM
  #127
bjmax's Avatar
bjmax
Chain is ok. No worry.
Old Feb 4, 2012 | 07:57 AM
  #128
mgrotel's Avatar
mgrotel
yea, im not worried about it. but just to make sure, you rotated the crank a tad away from the marking on the oil pump so that all the other timing marks lined up, correct?
Old Feb 4, 2012 | 09:03 AM
  #129
bjmax's Avatar
bjmax
Thats right.
Old Feb 4, 2012 | 11:16 AM
  #130
mgrotel's Avatar
mgrotel
good deal, thanks
anyone remember what color the connector is that connects to the pass side cam sensor?
Old Feb 4, 2012 | 11:28 AM
  #131
mgrotel's Avatar
mgrotel
i think its green
Old Feb 4, 2012 | 11:40 AM
  #132
bjmax's Avatar
bjmax
It is gray see here.
http://www.youtube.com/watch?v=1U5xE...e_gdata_player
Old Feb 4, 2012 | 11:48 AM
  #133
mgrotel's Avatar
mgrotel
looks green in post 22 here:
http://g35driver.com/forums/engine-d...sensors-2.html
Old Feb 4, 2012 | 07:33 PM
  #134
johnwigs's Avatar
johnwigs
giant air leak is the fresh air filter you have for your PCV system... if you are useing a MAF then it is allowing unmetered air to enter your engine... yes it is not going into the cumbustion chamber directly but the air is going down your oil drains to the pan then back up the B1 oil drain through your PCV valve and into your intake manifold creating a lean condition during cruising speeds, which could lead to an intermittent misfire... how do I know this? I have seen it at least 50 times... and as long as uhohzone keeps selling them, I will keep seeing it.
Old Feb 4, 2012 | 09:50 PM
  #135
mgrotel's Avatar
mgrotel
You're right, for some odd reason I was thinking the stock setup pulled air from an unmetered source, but it is metered. I'll put it back to stock. I plan to go with an electric pcv pump anyway so with that I shouldn't get any oily air going back into my intake. That's all I was trying to avoid anyway.
Old Feb 5, 2012 | 07:29 AM
  #136
mgrotel's Avatar
mgrotel
anyone know if there is some sort of saftey feature on my 06 g35 what will prevent it from turning over if some sensors are unplugged, or if maybe its in safe mode or something? my fob works to get in and turn things on, but it wont turn over. also, the buttons on the fob dont work, like the lock, unlock, and trunk buttons, but if i use the button on the door handle then it will unluck. i checked the battery and it shows 12v. its been sitting for a while with the batt disconnected though, about 2 months. was thinking about trying to jump it. i dont have the plen or intake on, just wanted to turn it over a few times to get oil pressure before i tighten down the spark plugs.
Old Feb 5, 2012 | 09:36 AM
  #137
0jiggy0's Avatar
0jiggy0
Sounds like a NATS issue. Why dont you build up the oil pressure by cranking it with everything together like everyone else on planet earth does?
Old Feb 5, 2012 | 12:52 PM
  #138
Classy's Avatar
Classy
I didn't bother turning over my motor until it was completely assembled minus the cooling system and everything from the radiator support, fired up, just didn't run it that long
Old Feb 5, 2012 | 01:05 PM
  #139
johnwigs's Avatar
johnwigs
Not a NATS problem... the engine should be able to crank without the ECU plugged in... check battery voltage or the solenoid connector... plus I don't know why this is being done with the engine not fully assembled... electric PCV? Just use a catch can like everyone else and empty it every oil change shouldn't be alot of oil in there... or else your rings are having some blowby problems
Old Feb 5, 2012 | 08:25 PM
  #140
mgrotel's Avatar
mgrotel
Motors running
