my turn
Old Feb 8, 2012 | 11:44 AM
  #161
mgrotel's Avatar
mgrotel
the hard start also seems to only happen when the oil is cold, if it turn the car off then right back on, it starts just fine, which again leads me to the thick oil being the problem
Old Feb 8, 2012 | 12:00 PM
  #162
Zazz93's Avatar
Zazz93
Do you have Cipher, if so that could be useful to diagnose. If not, not a bad time to look in to it.
Something else to check, when I first rebuilt the engine I was sloppy with my RTV and found that stuff everywere, including in the VTC Solenoid, pull it apart and check. Normally, the seals can take a removal or two and not leak. Once you pull it apart, it wouldn't hurt to check its voltage/resistance against the FSM.
Old Feb 8, 2012 | 12:12 PM
  #163
bjmax's Avatar
bjmax
I think it is the oil. I had the same and also a p0300 rough idle. I had a defect in the solenoid.
Old Feb 8, 2012 | 12:14 PM
  #164
mgrotel's Avatar
mgrotel
i will be tuning with uprev and so i already have the cipher cable. what should i log? is there an option to log variable intake angles?
i was pretty careful with the rtv around the solenoids, pretty sure there isnt any in there, in fact, i dont recall the fsm calling for any rtv around the solenoids. something i did do that i probably should not have, is reuse the gaskets for those vtc solenoids. the gaskets sure looked fine, but maybe that was not a good idea. i still have a hunch that its the oil in there though. thanks for all of the suggestions!
Old Feb 8, 2012 | 12:35 PM
  #165
bjmax's Avatar
bjmax
Be sure that it is installed right en the rubber O rings are in there. What oil ur using now?
Old Feb 8, 2012 | 12:41 PM
  #166
mgrotel's Avatar
mgrotel
rubber o rings? for the vtc solenoids on the front of each valve cover?
the oil is some joe gibbs break in stuff, i cant remember the weight of it. it seemed thicker when i was pouring it in though
Old Feb 8, 2012 | 12:53 PM
  #167
bjmax's Avatar
bjmax
Mixed something no O ring. That's in the tensoner.
Old Feb 8, 2012 | 12:56 PM
  #168
bjmax's Avatar
bjmax
Old Feb 8, 2012 | 01:34 PM
  #169
mgrotel's Avatar
mgrotel
yea, the fsm says to discard those gaskets, but mine looked fine so i reused. i dont see why that would cause any trouble though, there is no oil leaking around them at all
Old Feb 8, 2012 | 05:12 PM
  #170
Classy's Avatar
Classy
If you have a bad solenoid, let me know, I have one that is still good
Old Feb 8, 2012 | 09:10 PM
  #171
bjmax's Avatar
bjmax
i have reused the gasket.. thats no problem. I shout take it off and clean the oil out and reinstall it.. it can be dirt or what you think the break in stuff..
Old Feb 9, 2012 | 05:52 AM
  #172
mgrotel's Avatar
mgrotel
now i have a bad idle and the motor has a loud clattering at idle as well. also a p0300 code in addition to the p0021 code now. im scared, lol
Old Feb 9, 2012 | 06:00 AM
  #173
mgrotel's Avatar
mgrotel
the clattering goes away once the rpms hit a certain level, its not high, just off idle pretty much. so im guessing my oil pressure is not where it should be at idle???
  #174
bjmax's Avatar
bjmax
See my post above
Old Feb 9, 2012 | 06:20 AM
  #175
mgrotel's Avatar
mgrotel
yea, thanks for that
this oil is supposed to have a ton of zinc in it to bond to internals for better lubrication. you think its possible that the zinc is sticking to my cam sensors since they are magnetic and that it is also clogging up the vtc solenoid?
Old Feb 9, 2012 | 06:21 AM
  #176
mgrotel's Avatar
mgrotel
how much you want for that solenoid?
Old Feb 9, 2012 | 06:34 AM
  #177
mgrotel's Avatar
mgrotel
after work today, im going to change oil and put it full synthetic and also switch my two vtc solenoids to see if the problem switches banks, or hopefully just goes away
Old Feb 9, 2012 | 11:08 AM
  #178
bjmax's Avatar
bjmax
Clean the valve out. And see what happen.
Old Feb 9, 2012 | 11:35 AM
  #179
mgrotel's Avatar
mgrotel
yea, ill clean then out some when i have them out. i am pretty sure they are the same part so they should be interchangeable
Old Feb 9, 2012 | 11:51 AM
  #180
Zazz93's Avatar
Zazz93
I don't think you can switch the solenoids around because they are side specific. More and more I think you're a tooth off on the timing. Maybe Cipher has a log parameter that can verify it.
