my turn
Old Feb 13, 2012 | 08:22 AM
  #201
bjmax's Avatar
bjmax
On The 350z you have a pressuresensor standard. I don't know if the G has it. Can someone tell that plz.
Old Feb 13, 2012 | 08:24 AM
  #202
kacz07's Avatar
kacz07
Originally Posted by Classy
This kinda stuff irritates me... I have gone through a very similar problem when I built my motor, and after it all I would not have traded it for some shop to do the work, there only 3 shops in the WORLD that I would have do this kind of work for me and there are nightmare threads all over the Internet about shady shops.... I know I did the work, I know I did it right.
Mrgrotel, keep up the good fight and get it fixed!!!
+1. Useless post.
Old Feb 13, 2012 | 08:28 AM
  #203
mgrotel's Avatar
mgrotel
is that something that osiris reads do you know?
Old Feb 13, 2012 | 08:31 AM
  #204
bjmax's Avatar
bjmax
Old Feb 13, 2012 | 08:33 AM
  #205
mgrotel's Avatar
mgrotel
i will, ill get it figured out. i dont let things bother me. some people are the opposite of you, classless, and there isnt anything i can do that will change that.
  #206
bjmax's Avatar
bjmax
If There is à sensor you can.
Old Feb 13, 2012 | 08:35 AM
  #207
mgrotel's Avatar
mgrotel
thanks bjmax, im sure that sensor is the same for the g35. so you just unplug that and use that tester to see what the pressure is? where do you get that tester?
your iphone battery is getting low, lol
  #208
mgrotel's Avatar
mgrotel
just read your last post, ill check on osiris first before i crawl under there to look, thanks
Old Feb 13, 2012 | 08:48 AM
  #209
mgrotel's Avatar
mgrotel
i know my oil pressure light works, because it was on right away when i first started the car since it had to build pressure, but it has not been on since, so idk, maybe my oil pressure is fine, ill still check but just thinking/typing out loud here.
Old Feb 13, 2012 | 09:03 AM
  #210
bjmax's Avatar
bjmax
I can't hear the noise good enough. Is it the chain you hear or something deeper inside?
Ps loading my iPhone
Old Feb 13, 2012 | 09:38 AM
  #211
Zazz93's Avatar
Zazz93
Yeah, check the pressure and make sure your at or above the minimum pressure at idle. Hopefully, the code was just the solenoid.
Old Feb 13, 2012 | 10:51 AM
  #212
mgrotel's Avatar
mgrotel
im not even sure myself, ill look into it closer pretty soon
Old Feb 13, 2012 | 10:52 AM
  #213
mgrotel's Avatar
mgrotel
ive now gone 80 miles, no code, almost positive it was a bad bank 2 solenoid. and this noise might be my exhaust hitting somehting but i dont think it is
Old Feb 13, 2012 | 10:58 AM
  #214
mgrotel's Avatar
mgrotel
so im reading that osiris does not read oil pressure, and also that g35s dont even have that sensor. so where am i able to get that oil pressure tester?
Old Feb 13, 2012 | 10:59 AM
  #215
bjmax's Avatar
bjmax
Let Us know if you locate the noice where it is coming from.
Old Feb 13, 2012 | 11:06 AM
  #216
mgrotel's Avatar
mgrotel
if oil pressure was low, wouldnt my oil light be on?
Old Feb 13, 2012 | 11:20 AM
  #217
bjmax's Avatar
bjmax
If there is a oilpressure light yes. But then there should be a oilpressure sensor on there ;-)
Old Feb 13, 2012 | 11:30 AM
  #218
mgrotel's Avatar
mgrotel
from what i read, the 350z has a sensor for a gauge, and the g35 has a cheaper sensor to just trip a light when it does too low, so to check the pressure, ill need a gauge. but.....i know the light came on when i first started the car so i know the light works.
you know where i can get one of those testers?
Old Feb 13, 2012 | 12:02 PM
  #219
Classy's Avatar
Classy
So wait, the sound goes away at say 1000 rpm?
Old Feb 13, 2012 | 12:03 PM
  #220
mgrotel's Avatar
mgrotel
yea, when basically any throttle is applied, it sounds great and has good power. it just sounds like that at about 700rpm and below. does not do it when the motor is cold, probably because when its cold, it idles higher than normal till its warm.
