Nitrous Oxide Too soon, jr.
Direct Port
Old Jan 15, 2005 | 01:36 PM
Street Visionz, Inc.'s Avatar
Default Direct Port
It seems like most people on here have a single fogger wet setup. Has anyone gone the direct port route and if so please describe your experience. Thanks.
-Andrew
Old Jan 18, 2005 | 02:55 PM
RA11325's Avatar
RA11325
I did this setup on my celica, it works and look amazing, but the truth is, it takes alot more work and planning to build a direct port setup correctly and you are more than likely never gonna use that big of a shot that would require a direct port setup.
Old Jan 19, 2005 | 08:22 AM
Could you feel the difference vs. a single fogger setup? I'm planning on going this route as soon as the funds become available to me.
Old Jan 19, 2005 | 12:32 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
The main benefit of direct port is even N2O/Fuel distribution to each cylinder and a colder charge, because you wont be cooling the whole plenum and it has less time to pick up heat. The up/down side is direct port is a harder hitting system.
Total power is adjustable the same way it is for a single jet, you just use more of them with smaller holes.
Cost and complexity are the biggest factors for why people don't use it more often. Instead of one nozzle and a hand full of jets, you need six nozzles, adjustment jets for each, more tubing and a distribution bocks.
Installation will require you to remove the intake/lower plenum and drill and tap it six times and install all of it as well. When you sell the car, it all comes off again, unless the buyer wants it or you just disconnect it and plug it up and call it a day.
In the end direct port is technically better but single nozzle more practical for the average user.
In all of that, I am probably going direct when the time comes
Chris
Old Jan 20, 2005 | 08:03 AM
RA11325's Avatar
RA11325
You could run a bigger shot on stock internals as well, see with a single fogger setup, the cylinders closest to the intake or gonna take the hardest hit as they will get the most nitrous, making them more prone to damage. So on a small shot a single fogger is fine because you arent putting in enough nitrous to really hurt things, but on a bigger shot, say 100+ a direct port setup is much safer, as you could distribute the nitrous evenly to each cylinder, while a single fogger 100 shot might give a 30hp shot to each of the front 2 cylinders and divide the remaining 40hp to the rest of the car. However a 100hp shot on a direct port would only be about 16hp per cylinder, hardly anything dangerous.
Old Jan 21, 2005 | 10:39 AM
mrtomcat's Avatar
mrtomcat
interesting...
has anyone tried out the universal NX direct port kit that they now offer?
http://www.nitrousexpress.com/Pages/80004EFI.htm
Old Jan 21, 2005 | 01:22 PM
JeffesonM's Avatar
JeffesonM
not sure if the Maximizer works with a direct port setup but it can ramp up the shot so it doesn't hit all at once: NX Maximizer
Old Jan 21, 2005 | 02:00 PM
mrtomcat's Avatar
mrtomcat
it will in any setup because it allows you to control traction
Old Jan 23, 2005 | 01:44 PM
so is there anyone out there with a Z that has direct port?
Old Jan 23, 2005 | 05:29 PM
HyperSprite
Mad Scientist
I am pretty sure that Valvoline G53 with the flames has direct port and she is in the bay area but I don't know much else about it.
Chris
Old Feb 3, 2005 | 11:46 AM
g35irish's Avatar
g35irish
I am planning to install the NX direct port injection system along with my new Crawford cast plenum, once I receive it. This way I can reinstall the OEM plenum when I take the car in for service, therby removing the NOS system as well. I plan to make the electrical connections via terminal blocks, so there will be no remaining visible wiring for the system either. It should be pretty trick! I have used direct port injection in the past and found that the benefits far out weight the added cost/complexity.
Old Feb 3, 2005 | 12:25 PM
mrtomcat's Avatar
mrtomcat
I'm doing the same on the electrical side.
I spoke to NX a few days a go and they said someone in NY is using their NXL direct port kit on a 350Z and is loving it.
I just don't know how it would fit since the fuel rail is so covered up
Old Feb 4, 2005 | 08:57 PM
UsafaRice's Avatar
UsafaRice
the APS tall boy plenum is going to have some form of taps in it, it might be useful for dp
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Tochigi_236
Sep 27, 2015 03:40 PM
