Nitrous Oxide Too soon, jr.
my nitrous 1/4 mile times
Old Apr 7, 2006 | 07:38 PM
  #61
cj350's Avatar
cj350
I wana know now..
Old Apr 7, 2006 | 11:55 PM
  #62
Audible Mayhem's Avatar
Audible Mayhem
My350z
Default boo yyaaaa!!!!
https://my350z.com/forum/showthread....26#post2276726
Old Apr 8, 2006 | 05:00 AM
  #63
Old School's Avatar
Old School
Shift_Boost
Originally Posted by audiblemayhem
your af should be fine with those jets, i am running a 125 shot now, about 105 to the wheels, i might go get some bigger jets today for the hell of it.
i would get a wideband so you can watch you AFR anyways so you will know exactly where its at!!
You should be getting 125 whp with a 125 shot jets. NX's shots are measure by whp. According to NX...it should come within 2% of the claimed power at the wheels. If you are getting some less, I'm curious to know why.
Old Apr 8, 2006 | 06:56 AM
  #64
Audible Mayhem
My350z
sorry man, not true, i dynoed this to prove it
their 100 shot equals 80 whp... but lots and lots of torque!!!
Old Apr 8, 2006 | 06:59 AM
  #65
jcarp's Avatar
jcarp
how much more torque does it give you?
Old Apr 8, 2006 | 07:05 AM
  #66
Audible Mayhem
My350z
on an 80 whp shot, at a low rpm, 3000 , you would never hit it this low on the street, i was just on the dyno, it was 170 ft pounds a torque to the wheels
80 hp 170 ft pounds a torque...
Old Apr 8, 2006 | 07:10 AM
  #67
jcarp's Avatar
jcarp
wow. kinda makes you never wanna let off.
Old Apr 8, 2006 | 07:41 AM
  #68
1bad350z's Avatar
1bad350z
awesome dude, i had a feeling you were gonna up the nitrous jetting, and im glad to see it worked out.
what kind of wheel/tire setup are you running??
my cars a track model and im getting ready to get some wheels and tires.
but i cant find much info on whats clears the rotors and brakes or what sizes are common, ive thought about 16 or 17" factory wheels and either a 255-60-16 or a 275-40-17 et street drag radial, what do you recommend??
by the way i jumped my jetting up to im at 61N/28F and still have the fuel enrichment module hooked up A/F is 11.8-12.0 and it feels much much better, again CONGRATS!!
Old Apr 8, 2006 | 08:04 AM
  #69
Audible Mayhem
My350z
i am running a 62 and 34 now, you might want to up the fuel just a bit to even it out....
it is sooooooooooooooooo sick on the street, i really need some wide drag radials cause i get it REALLY sideways now in 4th gear going 80...
i dont have brembos and am running weld 96 prostars 15X8 s with MT ET drags 26X8.5s
also i hope you are using something to retard the timing on your car with that much hp....
Old Apr 8, 2006 | 08:12 AM
  #70
jcarp's Avatar
jcarp
is it hard to retard the timing with the utec.
Old Apr 8, 2006 | 08:29 AM
  #71
1bad350z's Avatar
1bad350z
im going to nissan monday and using the consult to retard the timing 5 degree's, thats the max it can do, but that should be about perfect, it will slow me down on all motor because it will be like that all the time but when i go run at the track i will not be all motor....lol....plus its free and easy!
by the way man you should think about going to Carolina Dragway in Augusta Ga on June 3, its a event called Braggin Rights, its big and i would love to have a couple of fast 350's there, heres the link
http://www.bragginrights.org/
Old Apr 8, 2006 | 08:41 AM
  #72
Audible Mayhem
My350z
i wouldnt do your timing that way, last night i went to run all motor and left my retarded timing map on by accident, i ran a half a second slower and trapped 6 mph less, on the dyno with that map i lost 30 hp cause of the timing...
i would get a utec at least... the retarded timing makes the car feel like CRAP!!!
man i would love to but we rented out the whole gainesville track that day..
Old Apr 8, 2006 | 07:55 PM
  #73
bacalhau16's Avatar
bacalhau16
awesome times man. 1.6 60 foot is freakin impressive. keep up the good stuff.
i take it u never got just an N/A run then!
Old Apr 9, 2006 | 03:25 AM
  #74
Audible Mayhem
My350z
nope i ran once and right when i took off and floored my car i knew i left the retarded timing map on my utec, i was soooooo pissed !!!
Old Apr 12, 2006 | 08:55 AM
  #75
Old School's Avatar
Old School
Shift_Boost
How much are you retarding the timing? 2 degrees? I thought you were running stock timing until you bought the UTEC.
Old Apr 12, 2006 | 03:04 PM
  #76
Audible Mayhem
My350z
i have the timing retarded 5 degrees with a 150 shot, i had it stock timing with my 100 shot yes and no problems,
that run i made was with retarded timing 13.4 @102, with the exact same setup i ran 12.90 @ 106
nothing different, thats how much the timing retard will effect the car...
Old Apr 12, 2006 | 03:14 PM
  #77
RedondoG's Avatar
RedondoG
oops
Old Apr 15, 2006 | 08:39 PM
  #78
done12many2's Avatar
done12many2
The Consult will only allow you to add or pull 2 degrees of timing. You can go to -2 degrees and up to +2 degrees.
Old Apr 16, 2006 | 03:18 AM
  #79
Audible Mayhem
My350z
thats what i thought but i wasnt sure cause i have no experience with it. i would never want to drive around with retarded timing map all the time. it sucks.
Old Apr 16, 2006 | 09:32 AM
  #80
done12many2
I agree. Some suggest the retarding or advancing does nearly nothing, but I know for a fact that I can feel it. I use the Cipher to pull and add and you can fell it right away. As a matter of fact, while you are doing it at idle, you can here the tone of the exhaust and motor change as you add or pull.
