Nitrous Oxide Too soon, jr.
Colder Plugs for VQHR
Old Jun 19, 2009 | 11:20 AM
The Guy's Avatar
The Guy
Default Colder Plugs for VQHR
Where do you purchase one step colder plugs for the VQ35HR? I have found numerous sites for the DE motor but I know they are not the same plugs. NGK site does not list having a spark plug for the 07-08 z, any information would be helpful.
I just purchased a Zex kit with all the goodies, looking for spark plugs so I can do the install all at the same time.
Thanks!
Old Jun 19, 2009 | 12:37 PM
350z 6spd's Avatar
350z 6spd
stock 370z plugs
Old Jun 19, 2009 | 12:40 PM
coachk's Avatar
coachk
Old Jun 19, 2009 | 12:41 PM
coachk's Avatar
coachk
Links not working....just go to www.gtmotorsports.com
advance search and type in colder plugs
Old Jun 19, 2009 | 12:47 PM
The Guy's Avatar
The Guy
Originally Posted by coachk
Thats 200+ with shipping for spark plugs!!
So stock 370z plugs are 1 step colder for VQ35HR? I would probably have to go through the dealership to purchase them.
Old Jun 19, 2009 | 12:53 PM
350z 6spd's Avatar
350z 6spd
Yes. The 370 plugs are a Denso fxe24hr11 and the stock 350 hr plugs are a Denso fxe22hr11. I got them at my local dealer for wholesale which was 8.xx a piece, courtesy sells them for 9.90 a piece. Though for some reason courtesy is listing the 370z plugs as fxe22hr11, the ones I got from my dealer were definitely fxe24hr11.
Old Jun 19, 2009 | 01:08 PM
The Guy's Avatar
The Guy
Great information!! Thanks a lot that will save my quit a bit of money.
Is this a platinum plug? Is that ok for a nitrous application?
Old Jun 19, 2009 | 01:16 PM
350z 6spd's Avatar
350z 6spd
No problem
Old Jun 19, 2009 | 02:29 PM
Italianjoe1's Avatar
Italianjoe1
I wouldn't run platinums with nitrous, the smaller electrode can cause detonation, it gets much hotter while spraying than it is designed to do and can start to act like a glow plug.
Copper plugs are the best bet for nitrous apps. They are also much cheaper, so if you are really worried just change them more often, still cheaper than a set of platinums and they work better.
Old Jun 19, 2009 | 03:13 PM
350z 6spd's Avatar
350z 6spd
The densos are iridium not platinum. I'm almost positive that nobody makes one step colder copper plugs for the hr, or at least no one did when I bought them and when everyone was discussing it a few months ago.
Old Jun 19, 2009 | 11:27 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
For nitrous application, copper plugs are highly recommended. Iridiums will work, but I'd check those often, especially right after you install your nitrous and test them, just in case. Platinums are a no-no.
Old Jul 17, 2009 | 07:04 AM
The Guy's Avatar
The Guy
Default update
370z plugs work great, no problems with idle or when spraying. Il be checking them on my next oil change just to make sure.
Old Dec 13, 2009 | 06:41 PM
stinky350z's Avatar
stinky350z
i need to replace my oem spark plugs on my hr what plugs should i use ,
ive seen the hks ones can i use the 370z ones?
Old Dec 13, 2009 | 06:58 PM
stinky350z's Avatar
stinky350z
thanks 350z_6spd
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
35reilly
Sep 28, 2015 07:42 AM
