Nitrous Oxide Too soon, jr.
Wiseco 11:1 pistons and spray
Old May 25, 2015 | 10:39 AM
fr0ntline's Avatar
fr0ntline
Default Wiseco 11:1 pistons and spray
Hi all, first post here in the 350z forums
I recently acquired a 04 G35 5AT and im in the process of rebuilding the bottom end. im getting 96mm Wiseco pistons (11:1) along with eagle rods.
i plan on buying a nitrous express wet kit and running a 100 shot, my question is, assuming i have a wideband and check the A/F ratios and everything. will it be safe to spray a 100shot at 11:1 compression?
bear in mind this is my first N/A car and my first time messing with the bottle
Old May 25, 2015 | 03:44 PM
Conway_160's Avatar
Conway_160
You'll be fine, just know your Transmission is your weak point.
Old May 25, 2015 | 03:58 PM
bealljk's Avatar
bealljk
what are you tuning with? Am I missing something here?
Old Jun 5, 2015 | 12:42 AM
fr0ntline's Avatar
fr0ntline
not tuning, running stock ecu
Old Jun 5, 2015 | 12:46 AM
tcode's Avatar
tcode
Very very bad idea spraying it without tune.
Old Jun 5, 2015 | 05:00 AM
RedxNemesis's Avatar
RedxNemesis
wet shot or dry shot?
Old Jun 5, 2015 | 06:39 AM
Italianjoe1's Avatar
Italianjoe1
If the timing isn't advanced over stock and the a/f is rich enough (high 11's ideally), the extra compression won't matter. If you want to stay at 100 or go higher, I would suggest having the car tuned for the nitrous, as the timing should be reduced 2-3 degrees where you are spraying the car, as the nitrous itself causes a faster burn and has the effect of advancing timing more, so it can cause detonation where there wasn't any before if not tuned accordingly, and detonation on a nitrous car breaks things quickly, as the cyl pressures can be many times higher than what an N/A car will see.
Old Jun 5, 2015 | 11:11 AM
fr0ntline's Avatar
fr0ntline
planning on buying the Nitrous Express wet kit. the one that brings the solenoid for fuel and nitrous. i will also run a wideband guage to be safe, just wasn't sure if having these pistons would change anything
hulkout
Aug 15, 2019 02:01 AM
hardkicks
Sep 20, 2015 12:28 PM
